Old May 1, 2011, 10:01 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Yup, synth tests only tell half the story....and can LIE.
They are good for certain things like POTENTIAL. but thats about it.
Though one thing I disagree over is relying on QD of 1 for "quick and dirty" POV for SSD's. Personally, thats just too low a que depth. I used to think it was great...but since then I have found it to be a tad...misleading. In a modern OS the depths are usually deeper than one yet shallower than 32. I personally would love to see CDM and / or AS-SSD add in QD 2 and QD 3. In the mean time I usually take the QD1 results as "minimum" and the QD32/64s as "maximum" with real world speeds falling somewhere in between the two extremes (though closer to 1 than the deep end). Thats why I find the new Vertex 3 to be faster in real life than the C300. No idea on the C400 as I havent played with one yet.
The dif between the Crucial and Intel using basically the exact same hardware is (IIRC) Intel writes their own custom firmware for their version. Only time will tell who is "better" at it. ;)
Old May 3, 2011, 10:03 PM
ipaine's Avatar
Originally Posted by lowfat View Post
Can you direct me to some real world tests? That is another thing that bothers me w/ most SSD reviews. They all seem to rely on synthetic benchmarks.
I believe you can find some real world tests here:
OCZ Vertex 3 240GB Solid State Drive Review
"Nothing sucks more than that moment during an argument when you realize you're wrong."
OCZ Unveils the Vertex 3 and Vertex 3 Pro SATA 6Gbps SSDs FiXT Press Releases & Tech News 6 February 27, 2011 02:40 PM
OCZ 240GB Extended rjbarker Storage 9 November 27, 2010 11:41 AM
You can connect the ocz revodrive in pci.e 16x?? r.o.g Storage 3 October 29, 2010 07:42 PM
Patriot Launches 60GB, 120GB and 240GB Inferno Series Sold-State Drives FiXT Press Releases & Tech News 1 July 28, 2010 12:24 PM
