Old April 25, 2011, 07:55 PM
Default C300 VS Vertex 2
Hi!
I'm looking at upgrading my 30GB Vertex SSD for a 60+gb SSD. There seems to be really good words about C300 and excellent read speeds, but write speeds seems really low compared to Vertex 2? And what about Corsair Force serie 60gb?
Old April 26, 2011, 08:09 AM
JD JD is offline
If you can hold out a little bit longer, please do. Vertex 3 and other 2nd gen Sandforce drives are on the horizon.
Old April 26, 2011, 01:39 PM
JimboToronto's Avatar
Another consideration is whether you have SATA3 or not. Even the first-gen Sandforce in a Vertex2 is bottlenecked by SATA2. The C300 is a SATA3 drive and would be bottlenecked at less than 300MB/s if run at SATA2.
SATA3 is just a short-term patch anyway. It's almost obsolete even before it's been fully implemented. Multiple-controller SSDs have already surpassed its bandwidth. HSDL and other PCIe connections are the only way to go.
Old April 26, 2011, 02:28 PM
Yeah no problem here for Sata3, I will try waiting then ;)
OCZ Unveils the Vertex 3 and Vertex 3 Pro SATA 6Gbps SSDs FiXT Press Releases & Tech News 6 February 27, 2011 01:40 PM
Crucial Shipping C300 6Gbps RealSSD FiXT Press Releases & Tech News 1 October 14, 2010 04:02 PM
pls help, C300 64gb 30% performance alexkissu Storage 6 October 11, 2010 07:20 AM
Helluva good deal on the C300 256 GB turtletrax Storage 2 May 1, 2010 02:25 AM
