I've got a small problem with my current build. I don't need a DVD drive, but it would be nice to have one so I was looking for the smallest internal DVD drive I could find and it appears that the shortest depth is 170mm. I'd like one that's about an inch shorter, otherwise it won't fit in my case.
Are there any drives less than this? I'd use a slim drive but 5.25" bay adapters seem almost as long and wouldn't fix the problem...at least on Newegg.
I guess I'll use an external drive if there's absolutely no other way around this.
