-   -   mechanical vs ssd : the test of time! (http://www.hardwarecanucks.com/forum/storage/42443-mechanical-vs-ssd-test-time.html)
_dangtx_ April 11, 2011 11:40 PM
say you were to buy old stock, one of each, a mechanical hard drive and an ssd.to make it easier, say we're in the year 2020,or 2030,whatever,some time in the near future.
now, when you plug your drive in,say it was made 5 years ago but you just opened it up,wouldyou notice
any difference(performance etc) vs you plugging it in 5 years prior,i.e. right after it was manufactured..?
if 5 is not enough, how about 10 years? not enough? how about 20?
i figure ssd's shouldn't degrade much that fast, but the mechanical drives probably would...what say you? yes,you!
Shadowmeph April 12, 2011 10:06 AM
Logically thinking I doubt that any drive would degrade if it was just sitting in a sealed non magnetic dry bag and not banged around
botat29 April 12, 2011 10:09 AM
Mecanical HD have magnetic coating on the plater that will degrade with time and I always ear the bearing degrade with time even not in use. The motor, well I don't study the one use on HD, but very old electric motor do not work because they lost their magnet
enaberif April 12, 2011 10:10 AM
How could something "mechanical" degrade if it was never used?
Only reason anything degrades generally is if becomes used
_dangtx_ April 12, 2011 10:34 AM
was waiting for ak's input as well.
i found a stash i forgot about of old drives,like really old.
so i took out two and decided to drop them in some old machines...well one's doa(crr...fss..and such noises)
the other is slower than the old used drive lol.
AkG April 12, 2011 12:23 PM
HDDs will indeed degrade with time, whether or not they are used. The older ones (pre-FDB based ones) were notorious for ceasing up while on parts bin shelves (as in it was the backup for your online server and when a drive in your RAID went tits up...your "known good" replacement also failed on stratup). The newer ones are just more resilient but anything which is A) delicate b) requires PRECISION to work and C) relies on mechanical parts can and will degrade when talking about a decade+ of inactivity. IMHO the real killer is the fact that no one keeps them in hermetically sealed environments and over time the expansion & contraction + humidity...kill ems dead. THe motors cease, the heads get wonky, the magnetic layers of the platter degrade, etc etc.
IF we were talking like 3 or even 5 years on a shelf...then meh, I doubt many would die, but 10,20 or more years...many (probably most) would be toast. Now if ANY were to surive...then they would just be "slow" by modern stds..but I wouldnt be surprised if they too "wear out" faster than expected.
SSDs...no one knows. They havent been around long enough for a warehouse to "lose" and then find a crap ton of them from 10/20 years ago! :)
_dangtx_ April 12, 2011 12:59 PM
cool, thanks for the input man.
as far as ssd's, i figured if a stick of ram can go about 10-20 years without going bad, same should apply too right?
found some 512 pc 100's and 133's and proceeded to upgrade some poor souls old beaters without any issues :)
