Old March 27, 2011, 11:47 AM
Default Trim and raid?
I just noticed I can't enable trim on my 2x SSDs in raid0... not that its a big deal to me but was just thinking...
Old March 27, 2011, 12:16 PM
lowfat's Avatar
Yes that is normal. No RAID controller supports passing TRIM commands through RAID0 yet.
Old March 28, 2011, 11:33 AM
francisw19's Avatar
Yup...same issue here. The only thing you can do right now is just let the garbage collection do it's work. It works best if you let your machine sit idle for a while. A few times per month, I just turn my PC on and leave it at the login screen for an hour as suggested by OCZ.
Old March 28, 2011, 01:00 PM
My PC is never turned off...and since I can't fold while afk due to heat buildup in the room this shouldn't be too big an issue!?
Old March 28, 2011, 01:10 PM
francisw19's Avatar
You should be OK leaving your PC on all the time...as long as your SSD's get some idle time, then your OK. As I mentioned, the OCZ guys said sitting at the login screen is best.
RAID SSD's TRIM/GC Questions bkh2 Storage 5 September 15, 2010 05:48 PM
Does Vertex support trim in RAID 0 FreeKnight Storage 2 June 2, 2010 10:10 AM
Intel Raid driver with TRIM; anybody try this yet? chrisk Storage 10 March 21, 2010 12:04 PM
Raid now supports TRIM Musabi Reviews & Articles from the Web 4 March 20, 2010 09:09 PM
Raid and TRIM Smn123 Storage 1 February 28, 2010 07:36 AM
