Old March 25, 2011, 09:00 PM
JD JD is offline
Default Migrating Intel RAID
So I'm going to be moving some RAID1 arrays (3 to be exact) from an ICH9R to a P67 and was just curious if there's any way to do it without any data loss?
I'd rather not have to move all the data elsewhere and transfer it back.
Old March 25, 2011, 09:31 PM
Perineum's Avatar
It should work...
... but how, I don't know off hand. I haven't had to do it... yet.
Old March 25, 2011, 10:21 PM
KaptCrunch's Avatar
back up before any migration ....fail save
get current driver p67 rst f6 to load on install of OS
Old March 26, 2011, 11:25 AM
JD JD is offline
Theoretically though, since it's RAID1, both drives should have identical information.
As such, I know if I make the RAID using RST within Windows, there's an option to "keep data from x drive". Perhaps that'll work, but I guess I should really copy everything elsewhere first.
I do have a RAID10 on a LSI card of 1.8TB which might be sufficient, along with another 1TB or so on my desktop. It's just going to be a time consuming operation...
In my ideal world, I'd just plug the drives in and it would "remember" that it's RAID1 and be on my way I'm guessing it won't work like that though.
Old March 26, 2011, 12:37 PM
I recently moved my RAID0 array from my P5Q (ICH10R) to a P67 board. As soon as I set the storage mode to raid, everything was just as it was on the old board. No data loss, no headaches.
Old March 26, 2011, 02:04 PM
JD JD is offline
That simple?! Amazing. I hope it works out the same for me too then.
Old March 26, 2011, 02:08 PM
Intels ICHR controller is the same across ALL boards and nothing changes.
Its the one beauty of running a Intel SoftRAID setup :)
Old March 26, 2011, 09:25 PM
Perineum's Avatar
That's what I expected
Intel Chipset Driver Brings TRIM Support to RAID Setups FiXT Press Releases & Tech News 11 October 3, 2010 10:30 PM
SSD RAID support from Intel N.V.M. Storage 8 August 22, 2010 03:05 AM
Intel x25-v 40GB SSD RAID benchmark results Skullmunch Storage 2 May 18, 2010 02:38 PM
Intel Raid driver with TRIM; anybody try this yet? chrisk Storage 10 March 21, 2010 12:04 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
