Old March 21, 2011, 04:21 PM
biff's Avatar
Default HDD access issues...
I just added a new HDD to my system and after I rebooted Windows gave me a message that I needed to format one of my other HDD's before I can access it. WTF? This was a drive that I was already using and was working fine. I'm using windows vista home premium x86 and the drive is a WD15EADS. I've taken the drive out and put it in another computer and same message. Any ideas? Seems a little too much of a coincidence for a drive to go tits up at the very same time I added another drive.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old March 21, 2011, 10:49 PM
biff's Avatar
A little more info... using various 'data recovery' programs this drive is showing up as a ~500GB RAW partition. I don't know why only ~500GB and I've never heard of a RAW partition but most of the software can see the whole directory and file structure. So I don't think the drive is physically damaged anyway. I'm just starting to attempt some recovery now.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old March 21, 2011, 11:28 PM
wait, what partitions are you using on your drives? i always go old school and forget about the fancy stuff one may be
presented with,never lost a partition again. its possible it got confused about drive letters or something, or the new drive is with the
new advanced format(yeah,i saw the p/n :p) but vista should be fine...hmmm
Old March 22, 2011, 06:46 AM
biff's Avatar
Nothing fancy here so far as I know. When I originally got the drive I plugged it in and made the whole 1.5TB a single NTFS partition.
I'm wondering about what the BIOS is set on IDE/AHCI/RAID? I never check that kind of stuff. Would it matter? When I added the other drive I did a bit of cable rerouting so there's a good chance that it could have gotten plugged into a different SATA port on the mobo (which is a GA-965P-DS3). Not sure if any of that is relevant.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old March 22, 2011, 11:36 AM
biff's Avatar
You know... the irony of all this is that I was rearranging the drives to get them in place to do a 1:1 backup.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old March 22, 2011, 11:46 AM
on your first computer, it could be a mobo limitation, im not sure. but the second one?
also moving sata cables around should be ok, unless its on different controllers and you raided them before or something...
ak might help ya more on this disk issue here.
Old March 22, 2011, 12:16 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Sounds like the Vista system "ate" your MBR. Could have been as simple as the MBR was "dirty" when you yanked it from the first rig (could have been a bad cable, or one of a bijillion other things) and then Vista (notorious for this kinda crap) considered it a null / bad / etc partition and has marked it as such (aka marked it as a raw hdd)....which in turn toasted your file records (ie where the files and their data map to on the physical platters).
Right click on my computer, click on manage. Click on Disk Management. Is it seen as a raw drive? Is it seen as an UNinitialized drive (usually does if seen as raw)? IF its seen as needing to be initialized... yank the hdd, stick it back in the orginal system. It MIGHT be recoverable then (is you old sys will know what it is and consider it good). If so...back up your data. Run a chkdsk on it. Most likely it will come back and tell you it had to fix some things.
IF its seen as a raw hdd on the old rig. You can try "fixmbr program" (google it there are a couple out there like MbrFix.exe). It sometimes is able to unscrew things IF its the MBR that is toast. IF that doesnt work...Time to get out your fav data recovery tool and do it manually. :(
Couple rules for swapping hdds that I (try) to follow before doing it.
1) run a chkdsk on them to make sure everything is OK
2) if its important data....back it up BEFORE moving it
3) run fixmbr and backup the mbr table and save it to a thumb drive
4) when in doubt...stick it in a usb external enclosure. sometimes this extra hardware layer is enough to keep shit from going bad.
5) never, ever use Vista. Its crap when it comes to storage. Buggy, buggy crap.
Old March 22, 2011, 12:17 PM
KaptCrunch's Avatar
Click on "Performance and Maintenance", "Administrative Tools", "Computer Management", "Storage", "Disk Management"
what does disk management report
did you shut down or hot swap HDD's , also if HDD last role was locale not hot plugable setting in OS
the channel/port has corrupted the MBR on HDD for the first HDD (native) was written to non native HDD leaving HDD unallocated
other is can't go from Mac to PC different FAT
Old March 22, 2011, 01:17 PM
Mr. Gruntsworthy's Avatar
On the topic of Vista having buggy storage problems... i've been using vista for a couple years now, never had any problems relating to storing stuff. Save for one SSD that was Dead on Arrival, it's been flawless. No transfer/read/write throttling (except maybe my SSD, which reads @ 180mb/s instead of it's listed 250ish), etc
Then again, I've never tried any of the more fancy stuff like RAID or automatic backup.
MAIN RIG:
Case: CoolerMaster HAF 932
CPU : Intel i7-5820K 6-core @ 3.3GHz
RAM : 32GB DDR4 2400MHz (G.SKILL Ripjaws)
HDD : Main: 240GB SSD SATA2 (Intel) Storage: 3TB SATA2 (WD Green) Backup: 500GB External USB (Hitatchi)
GFX : Gigabyte GTX 970 4GB
PSU : 750W Corsair Modular PSU
MoBo: Asus X99-A
View : Acer H213H 21.5" @ 1920 x 1080 + random 4:3 monitor
Level/Game Designer, Programmer
http://mikeseguin.webs.com/
I run Durham 3D Printing, an online 3D Print shop!
Old March 22, 2011, 01:38 PM
biff's Avatar
Thanks,
I'll look up that info and report back. BTW I thought fixmbr was data destructive, as in it could revive an other wise dead HDD but chances on loosing all data and rendering it non-recoverable was pretty much guaranteed. Am I wrong?
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
remote access ( for free ) gingerbee O/S's, Drivers & General Software 12 December 28, 2010 11:33 AM
Help please! Cannot access website???? KRAFTIG O/S's, Drivers & General Software 20 November 25, 2010 08:37 PM
Transferring files from OSX HDD to a Win7 HDD feerof Storage 5 October 4, 2010 10:17 AM
Cannot access Private Messages Digikid Suggestions & Feedback 23 March 2, 2009 08:05 AM
Cannot access certain websites, intermittent website access chrisk Networking 16 November 30, 2008 12:24 PM
