Old March 6, 2011, 07:54 PM
Default Formatting a HDD
Alright so I decided to go ahead and put to use a 250 gb western digital HDD sitting in an old computer that wasn't being used. When I went into the disk management program to wipe the drive and format it I realized there was an OEM partition on the drive. This drive came from an older dell PC my sister used to use and so I'm guessing that partition had an image of the OS when it left the factory for recovery purposes. I followed this guide How to delete OEM Partition | Jared Heinrichs in order to delete thinking I'd be able to access the extra otherwise unusable space but now as far as I can tell it's gone for good.
There's two comments further down stating: "Unfortunately no it does not automatically add the now free space to the primary partition. You would need to use a partitioning program like Partition Magic. I’ve never tried this program but have heard great reviews on it. Partition Logic | Home If you use it let me know. It’s a free alternative"
and
"just wanted to add that after you do the diskpart…you go back into disk management and right click on the main partition (you will see unallcoated partion you just overrided) and select extend volume…. it will then walk you through it to reclaim that space into 1 partition…"
But neither of these options have worked for me! Here's an image of what the drive looks like in disk management, it's disk 1. If you look closely you can see that there's a bit of "missing" space at the end of the horizontal bar. ImageShack® - Online Photo and Video Hosting
If anyone has any experience with this the help would be greatly appreciated. If not, oh well, it's 18 gigs I wasn't going to be able to use anyways!
Old March 6, 2011, 08:02 PM
Mr. Gruntsworthy's Avatar
Delete all partitions on the drive, and then create a new partition, allocating as much space on the drive as you wish. Bam, done.
MAIN RIG:
Case: CoolerMaster HAF 932
CPU : Intel i7-5820K 6-core @ 3.3GHz
RAM : 32GB DDR4 2400MHz (G.SKILL Ripjaws)
HDD : Main: 240GB SSD SATA2 (Intel) Storage: 3TB SATA2 (WD Green) Backup: 500GB External USB (Hitatchi)
GFX : Gigabyte GTX 970 4GB
PSU : 750W Corsair Modular PSU
MoBo: Asus X99-A
View : Acer H213H 21.5" @ 1920 x 1080 + random 4:3 monitor
Level/Game Designer, Programmer
http://mikeseguin.webs.com/
I run Durham 3D Printing, an online 3D Print shop!
Old March 6, 2011, 08:06 PM
It looks like you did everything correctly. If there was any unallocated (unpartitioned) space on the drive you would see it in grey and it would say unallocated.
Even though the drive is labelled as 250GB you will never see that total in Windows, blame Microsoft! ;)
If you check in BIOS you'll see the full capacity.
Supposedly the reason is that HDD manufacturers use 10^3 (1,000) to define 1 kilobyte - Windows use 2^10 (1,024), hence the "missing" GBs!
Old March 6, 2011, 08:59 PM
Trial Member
Default Looks like you did it propperly.
I'm Jared from jaredheinrichs.com
Because of the way hard drive are made you always get let then what it is advertised.
For example:
I have a 1TB drive. In My computer it says: 931MB. This is the equivilant of saying I have:
1,000,202,039,296 "bytes". When Drive manufactures claim it is 1GB this what they are talking about.
When you removed the OEM partition that was originally on the drive you freed up that space so that you could have one continuous partition. If you hadn't removed the OEM drive you'd have lost 2 or 3 GBs for the recovery partition.
Anyways.
Message me if you need any help.
Old March 7, 2011, 06:20 AM
Ah well great news then! Thanks for the quick replies, I was trying to no avail to somehow find those "missing" gigs - now I know why. Btw Jared that was a great guide on your website, concise and easy to follow. Thanks again guys.
Old March 25, 2011, 12:45 AM
Default Re: Formatting a HDD
Try Partition Magic software for same.
Perl formatting help ! homer98 Off Topic 4 October 5, 2010 08:08 AM
Hard Drive Formatting Question shayan288 Storage 10 August 10, 2009 05:43 PM
Having trouble formatting Sata II drive Brian Storage 0 July 6, 2009 03:49 PM
Formatting Second HDD & One Other Question.... mlauzon Troubleshooting 12 February 5, 2009 08:53 PM
sata hard drive formatting issue in XP sirhc Troubleshooting 28 October 9, 2008 12:37 PM
