Old March 5, 2011, 01:51 PM
no_pulse's Avatar
Default Best Data Recovery Software?
I'm getting a lot of bad sectors on my WD hard drive. I've managed to safely move some of my files to a new HD, but certain files are sitting on bad sectors and when I try to move or copy them over, the HD locks up. Can someone recommend a reliable data recovery software that "might" be able to help transfer the files that are on bad sectors?
I know that Spinrite by Steve Gibson is a very good program, but was wonder if there might be some other programs that will do the trick too. Any help would be greatly appreciated.
Originally Posted by kruzn4evr:
"The peppers fired a warning shot. Some were so loud and echoing that I was later told a few folks in
other aisles had ducked, fearing that someone was robbing the store and firing off a shotgun."
Old March 5, 2011, 02:07 PM
chrisk's Avatar
Folding Captain
I use "Recover My Files" with a high success rate, but its not free. Used it for formatted and corrupted USBs, deleted files, etc.
Not sure how good it would be for data on a bad sector though.
Fold for team #54196
Old March 5, 2011, 02:26 PM
Xeven's Avatar
HDDRegenerator has always helped me in situations where "magnetic errors" are causing bad sectors. You might want to give it a try.
PSXeven. Batards of the World Unite!
The gap between happiness and utter misery is only but a few inches
Old March 6, 2011, 11:53 AM
Rison's Avatar
at work and home, i've always used TestDisk
TestDisk - CGSecurity
Runs under pretty much any OS and is very good at bringing back long formatted data.
I'll learn to manage my anger, when people learn to manage their stupid.
Old March 6, 2011, 02:14 PM
Just be careful to not try the same files that lock up too many time before getting everything you can. If the drive has physical damage to the platters then the more you try the more you increase the chance of creating more damage.
Once you are sure you have everything you need (minus the problem files) then try the suggested utilities.
Good Luck!
Old March 25, 2011, 12:45 AM
Default Re: Best Data Recovery Software?
There are so many data recovery services you can found through browsing the net but Kernel Data recovery services are the BEST, the software Kernel for FAT and NTFS is the best data recovery software in it's category and it preview you your data after scanning your hdd drive and give you the platform to select the selective files which you want to recover.
reliable Data recovery service? Psycho-Designs Storage 5 July 11, 2010 08:46 PM
data recovery from an untouched drive bissa Troubleshooting 2 May 6, 2010 01:45 PM
Data Recovery misterd Storage 1 January 13, 2009 11:08 AM
Data Recovery appplejack Troubleshooting 8 December 1, 2008 05:19 PM
Data Recovery Scart Storage 7 July 3, 2008 02:33 AM
