Old February 24, 2011, 10:38 AM
Default Reliably Erasing SSDs
Some may find this paper from Usenix FAST 11 interesting:
Reliably Erasing Data from Flash-Based Solid State Drives
http://www.usenix.org/events/fast11/...papers/Wei.pdf
iK ©
Old February 24, 2011, 11:36 AM
interesting. so basically if you use something like hdtune and gutmann an ssd it might not actually do much? :)
Old February 24, 2011, 12:22 PM
JD JD is offline
I usually use the manufacturer provided tools to "wipe" the SSD before reinstalling Windows.
In OCZ's case, they suggest "wiper" and "hdderase" depending on which controller you have. That's good enough for me. Only way to securely erase data is to destroy the drive IMO. Anything else just causes unnecessary wear.
Your Opinions on ADATA SSDs le2key Storage 1 November 13, 2010 10:11 PM
SSDs - Raid 0 worth going for? MrDiaz Storage 15 March 12, 2010 04:17 PM
Need Help with SSDs! revixd Storage 21 January 11, 2010 03:45 PM
Erasing and getting rid of VHS tape anelectricmind Off Topic 38 September 20, 2009 08:56 PM
Two SSDs in RAID 0, One HDD - help AmuseMe Storage 2 September 14, 2009 03:15 PM
