Old February 17, 2011, 10:07 PM
Originally Posted by AkG View Post
If size is an issue the Black 750
If you don't want to worry about NAND...the Black 750.
IF price per GB is your main priority...the Black 750.
All the above. And I tend to avoid being a first generation adopter.
Old February 17, 2011, 11:21 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Originally Posted by rapmaster View Post
Is there any performance differences between the WD Black 500GB and the 750GB?
I havent played with the 500, but as a rule of thumb, when are you talking about the same amount of data being pushed to two drives of dif size that are of the same gen and model, the larger ones are noticeably faster as they "stay" fast over a greater amount of data. The point where they stay faster is getting longer and longer as the platter density increases.
For example lets say you use 250Gb of space and lets assume the platters are 250gb in a given gen (just keeping it nice and simple here these arent 250 platters but the idea is the same).
This means the platters on a 500Gb drive will be half full (2x250 platters) but only 1/3rd full on a 750Gb drive(3x250platters). This means when you go to stick the 251st GB of data the 750 will be faster at writing it and when you go to read it, it will also be faster.
Another way of looking at, is if you fill up a 500GB with 500GB of data, past the 360'ish GB point it will be a lot slower (most hdds really TANK in the last 1/3 of their space), whereas on the 750 it will only be 2/3rd full and still clocking along nicely in the speed dept. Hell, in the case of the 750Black the read numbers didnt really dip below 100MBs until basically a bit past the 450Gb point (where it kind of plateaued until nearly the 500GB point where it really started to decline below 100mb/s)!
As I always say...get the LARGEST storage device you can afford. If its a 500 instead of a 250 or 750 instead of 500, get the larger one.
Hope that helps.
Old February 17, 2011, 11:32 PM
rapmaster's Avatar
Huh, learn something everyday, thanks AkG.
Quando omni flunkus moritati
Old February 18, 2011, 01:01 AM
Perineum's Avatar
Wonder how 2 of these drives in RAID 0 would do vs SSD offerings...
Old February 22, 2011, 02:19 AM
Dr. Nick's Avatar
Aww, right after I got a 500GB drive too.
Old February 23, 2011, 03:45 PM
MacJunky's Avatar
I am thinking I am about to buy one either this month or the next, my lappy's drive is done.
Western Digital Caviar Green 3TB Hard Drive Review Comment Thread SKYMTL Storage 13 March 11, 2012 12:17 AM
Western Digital Caviar Black 2TB Hard Drive Review Comment Thread SKYMTL Storage 25 January 5, 2011 05:17 PM
Western Digital Caviar Green 2TB Hard Drive Review Comment Thread SKYMTL Storage 10 February 16, 2010 10:34 AM
Western Digital Caviar Black 1TB Hard Drive Review Comment Thread AkG Storage 14 May 2, 2009 07:43 AM
