Old February 12, 2011, 12:50 AM
Default SSD trouble
I have a 60g Ocz Vertex for my OS,windows 7 pro, and a 500g caviar black in my i7 920 rig. The vertex is at firmware 1.1 and needs to be upgraded to 1.6. Can I copy my OS from the ssd,c:, to a separate partition in my hdd,d:, so I can continue to use the computer to do the upgrades to my ssd? When I'm finished I will do a clean install of the whole thing and put it back to the old configuration. If so ,how do I do it? I'm not an expert but I have a laptop so I can look stuff up while all this is going on.
Old February 12, 2011, 01:04 AM
Supergrover's Avatar
Ceate a image of the ssd on your hdd Backup and restore system software and PC system utilities for Windows and Linux OSs works well. Update the ssd with the firmware.
Restore the image stored on your hdd to the ssd, its that easy.
R.I.P.
Old February 12, 2011, 06:30 AM
gingerbee's Avatar
then use the pat tool Paragon Alignment Tool - Overview
Old February 12, 2011, 07:06 AM
You can use Clonezilla - About to create a backup image and restore after the firmware upgrade.
Old February 12, 2011, 07:34 AM
I thought Windows 7 aligns the SSD's on its own?
Old February 12, 2011, 10:21 AM
gingerbee's Avatar
it does but if ya use a backup it will not be done right ie 1024mb then you just use this tool on the said ssd but ya have to have another machine i think not sure if it works on os drive your running it off of
Old February 12, 2011, 10:33 AM
Thank's for the ideas. I found a SSD health program and ran it last night and found my SSD is at 1.4 and not 1.1 so thats a bonus,despite the fact is says 1.1 in the boot screen. If I add a second hdd, can I set it up so I can run my ssd and first hdd as I am now, and have the second hdd as a clean back up containing info from both other drives, so if I get corrupted,as I am now, I can just reformat the the first 2 and copy the OS and programs from the 3rd drive? Is that a raid set up or just the backup and restore program already in W7? Wiping and reinstalling everything on the drives is a time consuming pain. I have a evga 758 a1 board.
Old February 12, 2011, 11:08 AM
Not sure why you are doing what you are doing... I'll tell you what I did to update my Agility 2:
1) Create a disk image of C:\ and save it to another drive.
2) Update my SSD firmware by following all the steps.
3) Didn't boot or work (the SSD), panicked for a few seconds...
4) Clear CMOS and waited for 10-20 minutes
5) Booted computer and everything was normal, the SSD didn't corrupt any of the data on it and everything worked like before the firmware update.
Old February 12, 2011, 06:38 PM
I'm getting bsod's on a regular basis. Some say my telus air card is trying to load a bad program, The last was because of something not getting a timing signal in time. Other times I can't boot windows cause it can't find c: drive. My i7 920 is sometimes running at 100% cpu and is very slow. My laptop is running vista with a celeron processor and will boot faster than the pc. I have deleted all the telus and sierra programs but I got a bsod last night because of wireless watcher [telus air card ]. All kinds of good stuff going on and i'm not sure whats causing it. Some things are software and some act like hardware so I decided to wipe the whole thing,upgrade all drivers and clean all connections in the pc. I may remove my cpu cooler and make sure all is good there. Once I have eliminated the software issue and made sure all the cables are connected and clean, I'll see if it still has issues. I did get lucky and a friend gave me an old dell laptop he was going to throw out just before all this crap started so at least I can get to sites for help. Right now it's running better that my prized pc.
Old February 12, 2011, 07:54 PM
TopDogZero's Avatar
Sounds like you need a clean install of Windows more than a firmware update. Might as well do both?
Trouble with overclocking Varroa Overclocking, Tweaking and Benchmarking 34 January 15, 2010 01:54 PM
More computer trouble gimark Troubleshooting 8 November 16, 2009 04:51 PM
A little networking trouble. biff Networking 9 October 30, 2009 05:54 PM
2 little trouble. martin_metal_88 Troubleshooting 2 October 12, 2009 09:13 AM
Internet trouble lanken123 Troubleshooting 3 February 26, 2009 08:50 PM
