<~----> Recovering data from a failing drive - Hardware Canucks
Old January 20, 2011, 01:01 PM
Default Recovering data from a failing drive
The second drive (i.e., not system drive) on my older system is failing. It is a Seagate ST3250823A, 350 gig. It's the drive where I 'store' files for long-term purposes, but stupidly didn't actually back it up. So if it goes, so does a lot of data.
I've been considering using DiskPatch to clone the drive and the iRecovery for file rescue, both at DIYDataRecovery. But iRecovery can also do a disk image as well. My thread about this is here, along with the data from their analysis log and smart check.
My concern is that there may be only one more chance to run the drive and so I want to choose an approach or software that will have the best chance of success as a starting point for file recovery. Oh, yes, the CD-rom drive no longer works, so I'm using a diskette to run the tool. It's not USB-bootable.
The system in question is a Dell 8250, Win XP, 1 gig ram. The system drive is also of questionable health. At this point I just want to ensure that I can get the data off the second drive and then I will scrap the system.
Right now the system is working fine, but it does become unresponsive at times recently. I'm wondering if I should move the second drive to my newer system (specs below) for the cloning or is that risky for the drive.
Antec 300 * ASUS P5Q Pro * E8400 3.0GHz * XFX Radeon HD 4850
Corsair 2x1Gb DDR2-800 CL 4 * WD Caviar 640Mb AALS
Samsung SH-S223F DVD writer * PC P&C 750W * XP Pro SP3
Old January 21, 2011, 01:00 AM
Perineum's Avatar
I would move the drive to a stable system with fast cpu for the cloning. I would boot up and clone the drive and hope to hell it worked the first time. Acronis is a good choice.
Old January 21, 2011, 04:43 AM
Rison's Avatar
I would pull the drive to a stable system as Perineum said.
If you can't directly copy the data over (missing, corrupt, etc).. try TestDisk for file recovery - I have used it for years on bad drives and have had recoverys from disks other programs fail to recognize.
TestDisk - CGSecurity
I'll learn to manage my anger, when people learn to manage their stupid.
Old January 21, 2011, 08:43 AM
Thanks, I'm thinking this might be a good time to start praying
I'm sure I won't be able to directly copy the data, so I'll have a look at TestDisk. Thanks.
hard drive failing, need help cleansing ccm001 Troubleshooting 9 September 28, 2010 05:59 PM
data recovery from an untouched drive bissa Troubleshooting 2 May 6, 2010 01:45 PM
Recover some data off a corrupted drive Scart Storage 8 December 21, 2009 09:40 PM
data recovery external drive cappaj1 New Builds 3 June 7, 2009 08:47 PM
Failing and new hard drive question matsta31 Storage 10 January 19, 2009 05:54 PM
