Old January 12, 2011, 12:42 AM
Nevakonaza's Avatar
Arrow Raid 1 question
I currently have a Western Digital Green 500Gb 16mb cache Sata2 7200rpm hard drive for Storage,I was thinking of buying another WD green of the same size for backup,although the one thats a good price atm in the UK is a 32mb cache instead of 16 like mine.
Does the cache make any diffrence or does it have to exactly match in order for raid 1 to work?
many thanks in advance for replies
Old January 12, 2011, 02:19 AM
Perineum's Avatar
I would expect it to work fine however I probably still wouldn't do it because I'm completely anal that way.
Old January 12, 2011, 07:56 AM
gingerbee's Avatar
I personal dont use wd drives for raid because i have had time out issue's with them in raid. my2cents i really don't see how the cache would matter it never did when i used any other drives with different cache size
Old January 12, 2011, 02:26 PM
JD JD is offline
Alternatively you could just setup a single "backup" operation to the drive one a day/week rather than use RAID1 assuming that this is only a storage drive and doesn't hold your OS or anything.
But I would definitely recommend using the same RPM and cache size drive if you are to run RAID1 just to be safe.
Old January 12, 2011, 06:36 PM
dustin1706's Avatar
You can basically RAID1 any two hard drives, even if they are different sizes. The array will just be the size of the smaller drive.
The cache size shouldn't make any difference. I've RAID1'd two completely different SG drives before with no issues.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Raid question Olorin Storage 12 January 26, 2010 12:09 AM
Question on Raid 1 Bojamijams Storage 13 October 3, 2009 12:23 PM
I have a question about RAID... The MAX Storage 16 May 8, 2009 02:30 PM
RAID Question Wein13 Storage 7 October 12, 2008 06:15 AM
RAID question miggs78 Storage 17 August 30, 2008 03:12 AM
