Old January 11, 2011, 10:53 AM
Default Need help buy two 1tb drive or one 2tb drive.
I am in need of storage my 2tb black caviar is on its last gb. I have been doing some research and found out if you get 2 1tb drive are better than having 2tb drive (because they are unreliable due to there tech) or i might be wrong.
Is there a 2tb external hard drive that's reliable i am not looking at? I was going to be buy lacie 2tb hard drive from future shop, or 2 samsung f3 or f4 7200rpm, but i can't seem to find them in Toronto.
I don't want to spend 180 for another 2tb blacks witch would be the best thing to do, but i don't have the money right now i need your help thanks in advance.
Old January 11, 2011, 11:08 AM
martin_metal_88's Avatar
You could order one of these? Not the fastest 2TB drive sinec they are 5400 but for storage speed is not what matter. They also go down to 79$ pretty often
Newegg.ca - SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Old January 11, 2011, 11:19 AM
I'd also suggest a sister backup drive for every storage drive you have. Having a drive suddenly die on you and losing 2TB data probably wouldn't be fun.
Old January 11, 2011, 03:31 PM
wd for all mechanical drives in terms of reliability. gent up here is correct, but it gets expensive just for backups, unless the data is expensive itself :)
Old January 11, 2011, 04:07 PM
chubaka's Avatar
well, i would get a 2tb drive and save that extra space for a second 1tb/2tb purely for backup of important files.
Old January 12, 2011, 01:42 PM
Need some advice i got a friend who who wants to sell me a 1tb black caviar for 50 and a f3 samsung 7200rpm for 50, or buy the samsung 2tb that martin advised. Thanks to all who applied.
Old January 12, 2011, 03:01 PM
gingerbee's Avatar
personal i would just go with teh 2 tb wdears cause i have bought a few for clients and there quite/run cool.
Old January 12, 2011, 06:38 PM
The caviar greens 2tb are not reliable, I have seen many reviews, and it's ridiculous what the percentage of failure rate. The one that martin suggested are alot better.
Any other opinions.
Old January 12, 2011, 06:49 PM
Any other opinions.
could you drop some links plz? :)
Old January 13, 2011, 06:21 AM
If you check new egg review and alot of computer store like tiger direct, they show they don't last long. So i don't want to take the chance of losing 2 tb data, And yes i know half of those people that are using it are giving it bad review for DOA that doesn't count; but i went and looked at the samsung, and it has no where near that much bad reviews. I don't just look at the number i actually read it to make sure.
[WTB] WTB: 2TB drive (not WD Green!) oblisk Buy/Sell & Trade 1 July 15, 2010 09:14 AM
2TB Drive Selection Decisions kingnubian Storage 10 July 1, 2010 06:23 PM
Seagate Shipping 2TB 6Gb/s Constellation ES Drive FiXT Press Releases & Tech News 0 February 22, 2010 11:38 AM
[WTB] 2TB Drive oblisk Buy/Sell & Trade 10 November 8, 2009 04:30 PM
The best gets better!!! Western Digital 2TB Hard Drive Chilly Press Releases & Tech News 13 February 9, 2009 02:26 PM
