Ive been using the DVD drive
Sony AD-7201A 20x DVD±RW DL IDE Drive w/LightScribe (Black) Sony AD-7201A
It uses a IDE. After trying to research about these things I have learned that there are some kind of "configurations" you need to set for ide's along with other technical stuff.
Now since it died about a year ago (used the Internet, but today I need to reinstall windows) I'm going to purchase this Sata DVD drive.
Micro Center - LG GH22NS50 22X Internal SATA Super Multi DVD Drive OEM 392522
After researching about these I have the understanding that all you gotta do is plug and use. My question is, will the IDE port that used to be for my old DVD drive (which will no longer be there) effect my mobo/computer performance, or cause implications from not being used?
Will having a unused IDE port cause a performance decrease or problems?
