Old January 5, 2011, 12:22 AM
tangrisser's Avatar
Just FYI, make sure to align them after formatting in WHS since WHS is based on Windows 2003 and usually fails to align the drive correctly. The software provided by WD won't work under WHS and you'll have to use Win Xp or format it in Windows Vista or higher and then use it in the WHS.
I would recommend using WHS to format and then Win Xp to align the drive using software.
Check out my SALE page
Old January 5, 2011, 09:21 AM
CoolHandL's Avatar
I format all my drives on my main rig before deploying them, its using Windows 7 64bit Ultimate.
So i bought the 2 x 2TB Greens, then pulled the trigger on another one as it was sitting in my shopping cart at last weeks sale price of $79.99, so i now have a total of 4 x 2TB Greens plus the 4 x 640GB Blacks, for +/- 10TB, I do have another 1TB Green drive, but i think i will keep it in the Main rig for incoming downloads and some media.
Old January 5, 2011, 10:50 PM
Are you guys saying that the 2TB WD Green is fast enough OS or not? And how about the WinXP 4k problem? is that an easy fix? I dont like Win7 because it has no color management but XP does, go figure.
Old January 5, 2011, 11:01 PM
dustin1706's Avatar
The read and write speeds are pretty similar to say a Black 500 and I would call those speeds "usable" for an OS drive. However, as a 5400ish rpm drive, the seek time is what suffers. The random access time is actually nearly double that of a 2tb black.
Honestly I think they are a good drive, but I would personally recommend a small SSD, or at least a 1TB/2TB black for the OS, then the greens for storage.
For XP you just need to put the jumper in a specific postion on the drive, then recreate the MBR and partitions using windows storage management or fdisk.
Oh yeah, VIVA XP!
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old January 6, 2011, 12:13 AM
If you're barely going to use the computer, might as well go with the greens for storage. No one has to stick around to wait/watch their files transfer.
[WTB] Need a 2.5" IDE Laptop Hard Drive (120Gb, 160Gb, 250Gb, 320Gb) AdoP Buy/Sell & Trade 84 April 30, 2011 07:15 AM
[WTT] 4 x WD Black 1TB drives for X WD 1.5TB Greens Apollo4g Buy/Sell & Trade 6 January 22, 2010 06:30 PM
Opinion needed on my i7 build ali7up New Builds 4 January 17, 2010 10:30 AM
Opinion needed Gellidius Troubleshooting 5 July 4, 2009 11:07 AM
Printer opinion needed. NyteOwl Peripherals 4 August 31, 2008 10:26 AM
