Old December 30, 2010, 09:36 AM
Default Disk Cleaners and SSD
I was just wondering what the effect of Disk Cleaning utilities like R-Wipe & Clean or
Auslogics will have on SSDs. Especially since these utulities have different algorithms for
cleaning. My understanding is that these utilities don't just remove unwanted junk - they
overwrite the space - sometimes with several passes. Any comments please ?
Thanks.
ASUS Z97-DELUXE; INTEL i7 4790K ; NOCTUA NH-U12P; PNYGeForce GTX 760 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 10 PRO 64-BIT.
Old December 30, 2010, 02:55 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Good way to kill a drive quick is to use HDD secure delete programs on SSDs.
The TRIM command (and ITGC for that matter) will "over write" the no longer used cells by bring them back to their virgin state (FF)....no need for multiple passes....unless you are selling the drive and VERY OCD about it.
TBH, I dont bother with a lot of these garbage cleaning / Crap cleaner programs. I use spacemonger to see what is taking up room WHEN I notice it and take manual steps to correct it. YMMV
SSD as Boot Disk, HDD for Others Kommie986 Storage 4 September 12, 2010 01:25 PM
Disk Cloning and SSD MarkOne Storage 5 November 12, 2009 11:24 AM
Disk Boot Failure - Insert system disk and press enter? lanken123 Troubleshooting 5 May 13, 2009 07:23 AM
