-   -   Deleted System Reserved Partition (http://www.hardwarecanucks.com/forum/storage/39391-deleted-system-reserved-partition.html)
Malam December 29, 2010 03:38 PM
I deleted the system reserved partition on my Data Disk. The data is still ok and the programmes on it are ok. However, I now have 130MB of Unallocated space and no windows system reserved partition. Can I
1) just ignore the unallocated space or
2) backup the data on the disk , reformat and the whole drive and restore the data, or
3) ???? not really sure.
I want to be proactive before something happens. Thanks.
JD December 29, 2010 06:07 PM
So you still have one on the OS drive? If so, then don't worry about it.
Malam December 29, 2010 07:17 PM
Yes, I do have one on the OS drive. Is it worth making the effort to recover the 130MB ? or just forget it.
Thanks.
DRYJESUS December 30, 2010 11:42 PM
Thanks.
I'd just ignore it. The next time you reformat, you can combine the unallocated space with your OS partition.
Malam December 31, 2010 05:46 PM
Thanks guys - much appreciated.
