Old December 16, 2010, 11:04 AM
Question 6GB/s HDDs worthless?
My new 3GB/s WD Caviar Green 2TB only 20% slower than my new WD Caviar BLue 250GB 6GB/s.
Can mechanical HD fully utilise their bandwidth? Or is 6GB essentially for SSDs?
check specs for the ...specs.
Old December 16, 2010, 11:06 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Consumer level HDDs cant even saturate 3GB/s SATA 2.0 bandwidth let alone the new 6GB/s spec. 6GB/s is mainly for SSDs....BUT as time goes by hdds...MAY get fast enough to justify it. With that being said I do like the new'ish WD 1TB. Its a peppy little hard drive! :)
Old December 16, 2010, 01:35 PM
Peppy yes.
6GB/s fast no.
But they are definitely a nice little drive.
Old December 16, 2010, 07:20 PM
Blu's Avatar
Blu Blu is offline
Can I get a link to this new 1TB Drive? I'm in need of a new main OS drive for my normal PC, also is it better then the 2TB Black?
Old December 16, 2010, 07:29 PM
Not new.
Been out for awhile.
NCIX.com - Buy Western Digital Caviar Black 1TB SATA3 6GB/S 7200RPM 64MB Cache 3.5IN Dual Proc Hard Drive OEM - WD1002FAEX In Canada.
Old December 17, 2010, 04:16 AM
AkG's Avatar
AkG AkG is offline
Your 2TB black is faster. I like the 1TB as its CHEAP and FAST....whereas the 2's are "just" insanely fast. With that being said I cant wait for the 3TB Blacks to hit (which is probably going to be Q1 2011) so the 2s will get cheap. :)~
Old December 17, 2010, 05:45 AM
bojangles's Avatar
Hard drives will most likely never reach that speed in the near future.
As a correction though, let's not mistake people with GB/s and Gbps...two totally different numbers! For the uninformed, the OP is talking Gbps (gigaBIT per second, not gigaBYTE)!
[WTB] HDDs Infiniti Buy/Sell & Trade 5 July 23, 2009 07:34 PM
how many hdds for raid kyle_L Storage 15 February 9, 2009 08:49 PM
HDTach 3.0 and my HDDs. Patriote Storage 23 November 22, 2008 02:52 PM
Is it necessary to cool HDDs? RA3KW0N Air Cooling 23 November 20, 2008 03:45 AM
