Old December 12, 2010, 11:14 AM
CMetaphor's Avatar
Quadfather
Originally Posted by _dangtx_ View Post
it is possible, i guess. so far ive seen it put the swap on other drives and or partitions. which is not bad. but the boot thingie? hmmmm
The boot files (MBR) are normally put on the "primary master" hard drive. However, the hard drive given this "title" is the first one that windows detects normally, the HDD 0 as it were.
Old December 12, 2010, 11:18 AM
good call. ill try to replicate it. i know when installing 7 on my secondary drive's 3rd or so partition not too long ago it put all the files but swap where they are normally put, and disconnecting or wiping out everything else did not make it go 6 feet under.
Old December 12, 2010, 11:26 AM
bvsbutthd101's Avatar
Originally Posted by CMetaphor View Post
Please read my last post...
You have both a SSD and a HDD, two drives. Its possible the MBR was on the HDD, even if it didn't contain any OS files...
I disconnected the HDD when installing windows on my SSD
Old December 12, 2010, 11:29 AM
CMetaphor's Avatar
Quadfather
Ah ha! An answer! That being the case, its probably part #2 of my first reply. Try fixing your mbr for whichever version of windows you're using. Either way you'll need to use the install disk
Old December 12, 2010, 02:20 PM
Blu's Avatar
Blu Blu is offline
Originally Posted by chriskwarren View Post
This is the reason why I disconnect ALL hard drives when installing Windows 7, except the boot drive (ie. SSD). After the install is totally finished, I reconnect them.
Otherwise, Windows will put crap needed to boot on other drives, which is what CMeta is suggesting.
Huh, that's a pretty good pointer to remember, though I sort of followed the same procedure when installing windows the last couple of times but just so I knew it was the right hard drive I was installing to, not for this reason.
Old December 12, 2010, 02:28 PM
its not even drives as usb flash drives can do this or card readers then windows is installed to drive j: :p
Old December 12, 2010, 03:47 PM
ok, I put my windows disc in, clicked repair my computer, went to command prompt, and I typed bootrec.exe/mbrfix, and it said operation successful. Hopefully that worked, hasn't shut off on me so far. Just I have wait.
Old December 12, 2010, 04:03 PM
CMetaphor's Avatar
Quadfather
Good news! Its booted back into windows and everything sucessfully?
  #19 (permalink)
Old December 12, 2010, 06:02 PM
Spikemaul's Avatar
This has happened to me in the past.
  #20 (permalink)
Old December 12, 2010, 06:38 PM
well after I set my SSD to boot first everything worked fine, but just for safety precaution I did the mbr fix like you said. But yeah everything works fine now.
What happened to him? crazyhorsejohnny HardwareCanucks F@H Team 38 July 17, 2012 08:22 AM
weird thing just happened lcdguy Gaming 9 July 1, 2010 07:56 PM
What happened? jcmaz Suggestions & Feedback 20 June 21, 2010 01:38 PM
the 1 happened bissa Storage 7 February 11, 2010 11:03 AM
What really happened? jay51 Off Topic 1 November 12, 2009 07:20 AM
