<~----> NAS build questions - Hardware Canucks
Old December 6, 2010, 03:12 PM
lcdguy's Avatar
Default NAS build questions
ok so i am trying to build a small 4 drive nas that consumes as little power as possible so i am looking at gp drives for data and a ssd/cf for boot drive. Now here's my dilemma.
1. I would love an atom board that could run my sas card but i doubt i will find one for less than $130. so if there are any recommendations don't hold them back.
2. I will most likely be using either openfiler or whs i haven't decided yet. I will also be using 2TB wd GP drives since i already have 2. Do you think i will run into a tler issue if i use them in either a raid 1e or raid 1 configuration or linux software raid. (i know i don't have this issue with WHS and DE.)
all this is doing is providing network storage that's it. Here are the rest of the parts.
Norco RPC-230 Chassis
Antec Earthwatts 450
2x 2TB WD GP (will upgrade to 4 eventually)
8GB CF (or 40GB SSD)
IBM BR10i SAS/SATA Raid Controller
Intel Atom based board (either 330 or D510)
2GB DDR2/3
Nic is onboard Realtek crapfest on all the boards but there is not much i can do about that.
Ideally the perfect board would have 2 onboard sata connectors, 1 pci x8, 1 pci, intel atom. But i don't think it exists.
or a atom board with 6 sata ports or dual pci slots.
Old December 6, 2010, 03:22 PM
Arinoth's Avatar
You have to be careful with the atoms boards. Last i looked at them you actually do get 6 usable sata ports. You can 4 and 2 raid or 3 and 3 raid which you can use either one or the other. Its why i shied away from it.
Old December 6, 2010, 03:24 PM
lcdguy's Avatar
except the only board i saw with 6 ports was around $200+ which at that point i am wasting money and should just get a matx+amd chip which kind of defeats the minimizing power.
Old December 6, 2010, 03:26 PM
Arinoth's Avatar
Can you link me that one, I may have seen it when I was looking to update.
Old December 6, 2010, 04:44 PM
lcdguy's Avatar
way to expensive no to mention they use so-dimm memory. was hoping for something in the 100-130 price range (not including ram.)
Old December 6, 2010, 04:54 PM
tangrisser's Avatar
Sorry those were meant for Arinoth. I was about to edit and quote your original post but that seems like way too much effort right now :P
1.
NCIX.com - Buy ASUS AT3IONT-I Atom 330 DDR3 NVIDIA ION mITX 1PCI-E16 HDMI Video Sound GBLAN Motherboard - AT3IONT-I In Canada.
NCIX.com - Buy Zotac NM10-B-E MINI-DTX Atom D510 NM10 Express PCI-E16 PCI-E1 SATA Wifi Video GBLAN DDR2 Motherboard - NM10-B-E In Canada.
Unfortunately, Atom boards almost exclusively come in Mini-ITX (I recall seeing mATX but that was a while ago and I don't think it's being manufactured anymore) and those two were the only ones I could find with a PCI-ex4 slot or bigger.
2.
When you say GP drives, do you mean Caviar Green or the RE4-GP? If you mean Caviar Green, you might have an issue since it does not support TLER but if you are referring to RE4-GP, it should be alright since it does support TLER.
Check out my SALE page
Last edited by tangrisser; December 6, 2010 at 04:57 PM. Reason: epic fail on numbering
Old December 6, 2010, 05:24 PM
lcdguy's Avatar
the mini-itx is fine since the rpc-230 is a shallow case. Any word on the reliability of the zotac mobo's i am not familiar with them.
And yes i mean the caviar gp not the re
Old December 6, 2010, 06:27 PM
Arinoth's Avatar
That zotac one is one of the ones i was talking about. According to the manual sata connectors 1-2 are for ordinary sata hdd and sata connectors 3-6 are for creating sata raid. Zotac even lists it as have 4 sata, meaning you cant run all six at the same time.
ZOTAC NM10-B-E Atom D510 1.66 GHz Dual-core Mini ITX WiFi Intel Motherboard
Old December 6, 2010, 06:31 PM
3.0charlie's Avatar
Nice explanation about the sata ports of that Zotac board at the ncix forum. NCIX FORUMS - 4+1 SATA Ports or 6 +1 - Zotac NM10-B-E MINI-DTX Atom D510 NM10 E...
Nas build critique please odis172 New Builds 12 January 1, 2010 10:27 AM
NAS Build lcdguy Storage 25 December 31, 2009 01:22 AM
Do I need to build a Nas server or can I do this instead Shadowmeph HTPC Systems & Software 14 October 23, 2009 11:59 AM
Rackmount NAS Build lcdguy Case Mods, Worklog & Gallery 29 September 30, 2009 10:57 AM
NAS Build lcdguy New Builds 17 January 30, 2009 01:49 PM
