Old December 5, 2010, 08:40 PM
Default Raptor to whs?......
do you think it would be ok to add a wd velociraptor 159gb as the main (os) drive in my home server?
also planning on one for my other system.
reason i am asking is that ncix has the 150's on for 79.99 right now,
thx
rob123
Old December 5, 2010, 10:05 PM
ToXic's Avatar
thx
rob123
Id personally say for the few extra dollars and massive performance difference get a SSD. I had my eye set on a Sata 3 640GB raptor for a wile, but was unimpressed with the performance over a normal HDD.
I'm back, baby.
XPS 9560
Old December 6, 2010, 06:19 AM
Varroa's Avatar
WHS wouldn't treat a SSD very nice as the main boot drive since it would constantly be writing small files (called keytombs) to it (and reading them) which will wear it out faster (and it doesn't support trim either). It would be fast and would speedup the OS but you would need a 80GB SSD drive minimum. A velociraptor would work great for this as well but I would only use one if you already have one (don't buy one). I would use a WD black for my main OS drive if I had a choice myself.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old December 6, 2010, 06:49 AM
matsta31's Avatar
yes and performance added for the WHS wont change a lot. It is not like we boot the WHS server a loot, or launch application. and for the small file and everything, you wont see a real life difference.
Sold hardware again.....
Currently using WHS hardware....
Old December 6, 2010, 06:54 AM
I used an SSD for a WHS server. It was an older Kingston one I bought, this was way back before TRIM-supported drives were around.
It doesn't have to be 80GB (mine is 64GB), there's a workaround if you're interested.
Weird thing though. It was surprisingly slow when I ran it on a SATA port connected to the motherboard. But when I switched it out to run on a pcie1x sata card, it ran really fast. But it is a server, so it doesn't really get used much. There hasn't been any significant wear at all. Boots super fast as usual since day 1. And it's been running for a year now. (Though I wish it would die so I could warranty it and hope they give me an updated drive ;P)
And if you get an intel drive, you can run their SSD toolbox tool to do a manual TRIM, incase you ever need it. The main reason for using the SSD as your boot drive is they are a lot less likely to fail than regular HDDs.
Getting a raptor for a WHS is a poor choice in every situation.
Old December 6, 2010, 07:22 AM
martin_metal_88's Avatar
And getting a SSD is to. WHS spend most of their time open, since you will wright/read on the SSD it will constanlty swap file from the HD to the SSD which wont be faster alot in file transfer over the network because the HDD will slow the thing. Getting a nice and spacious fast HDD is the best thing IMO. Maybe not a WD raptor but a caviar black 1 TB or a blue 500 ( like 2%slower than a black lol )
Old December 6, 2010, 08:34 AM
You clearly don't read.
Old December 6, 2010, 04:05 PM
ToXic's Avatar
Wow I took windows home server as gibberish, disregard my post... I'm a idiot...
I'm back, baby.
XPS 9560
Old December 7, 2010, 03:15 AM
thank you for the advice. guess i will just wait for the boxing day sales to pick up several of the wd blacks
cheers
rob123
Folding@home with WHS p3t3rson HardwareCanucks F@H Team 8 February 10, 2010 06:07 AM
whs wont shut down rob123 O/S's, Drivers & General Software 10 April 11, 2009 05:52 PM
antivirus for WHS....... rob123 O/S's, Drivers & General Software 2 February 22, 2009 08:53 AM
Business idea for WHS and HTPC's yamawho Off Topic 4 July 23, 2008 06:50 AM
Home Benchmarks: 74GB Raptor vs 150GB Raptor Oversized Rooster Storage 16 April 18, 2008 11:14 PM
