I was thinking of Short Stroking my 2 1TBs in Raid0 because there is no way I will ever use that entire amount and I might as well benefit from the unused space. Not sure if this is how I would accurately figure out the capacity to put it at, but I ran a HD Tach sequential read speed and it generated this chart for a "quick bench" (8mb zones)
Now based off this graph would shorting it to 700GBs seem to make sense? That's where it appears to be at its peak and that is probably the most I'll ever use.
However the "Long bench" (32mb zones) shows this chart
There is that huge dip right around the 725GB range. But based on this 650GB looks ideal for speed/capacity
I would assume the long bench would be the more accurate one but I don't want to assume without getting some other opinions. What Capacity should I go for? Currently I am using 350 GBs so I do have a lot of leeway here.
Thanks for any input
