Old December 2, 2010, 01:34 PM
CMetaphor's Avatar
Quadfather
Default Dell Perc 6/i - Firmware Upgrade Possible?
"If your Perc isn't in a Dell-branded system, then a firmware upgrade is pretty much impossible"
- Dell "tech support"
Im getting sick and tired of trying to Upgrade the firmware on my DELL Perc 6/i and would like to know if anyone knows how to do this and actually make it work (since the dell update software checks for a dell bios on the motherboard) OR help me find a way to flash it to LSI Firmware/ Use LSI's firmware tools to flash the real Dell firmware.
I already know the Perc 6/i is based of the LSI SAS1078 chip, and that's all i have so far.
Im frustrated and tired with Dell's "oops sorry we can't do that" tech support.
Help?
Old December 2, 2010, 05:16 PM
CMetaphor's Avatar
Quadfather
Anyone? I've been trying to use the LSI's MegaRAID software to push the .rom file i found in update A11 for the Perc 6i firmware with no luck - it gives me a 0x13 error.
Old December 3, 2010, 08:30 AM
CMetaphor's Avatar
Quadfather
Uppity. I refuse to let this issue go.
Old December 4, 2010, 09:58 AM
CMetaphor's Avatar
Quadfather
Uppity.
Hasn't anyone with a Perc 5i (which is basically the same thing, sans Raid 50 I think) ever tried to upgrade their firmware? Cmon y'all...
Old December 4, 2010, 01:19 PM
lowfat's Avatar
PERC 5/i RAID Card: Tips and Benchmarks - Overclock.net - Overclocking.net
Did you take a look at this at all? If it is similar to the 5i at all then try this. When I had a PERC 5i a few years back this is the guide I followed.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old December 4, 2010, 01:55 PM
CMetaphor's Avatar
Quadfather
Thanks for the info Lowfat, reading through it all.... However, there is one point of confusion in that guide. It states to downgrade to 7.0.1-0061, flash, then flash again using the latest fimware... but it also says to only flash using Dell firmware?
Old December 4, 2010, 02:19 PM
lowfat's Avatar
Sorry I have no idea. It has been years since I've owned the card.
Queen of Dreams WIP
Big Lian Li
Complete
Old December 14, 2010, 09:22 PM
Trial Member
Thumbs up Yes this is possible - use LSI MSM with the Dell ROM
Yes it's quite possible to do this. I have Perc 5 and Perc 6 cards running in whiteboxes that I can easily upgrade the firmware in.
Use the LSI MegaRaid utility. Then get the appropriate Perc card "hard drive firmware update" package from Dell. Extract the package so you have the .rom file. Then just use the firmware update option in the LSI MSM utility to flash that rom file to the card. Works great, no problems.
Just make sure you get the EXACT match for your particular RAID card. Otherwise you will get a firmware update error. There is a separate ROM for the Perc 6/E, the Perc 6/i, and the Perc 6/i Integrated (YES even the Perc 6/i and the Perc 6/i Integrated are NOT considered to be the same and will NOT take the same firmware).
This also works with all of the Perc 5x cards as well, with the same caveats re getting the right firmware file.
Old December 14, 2010, 09:24 PM
CMetaphor's Avatar
Quadfather
Im fairly certain i tried Exactly why youre describing using the .rom file from 6/i .... I suppose ill double check it again. Would you have the link to the dell drivers you used for your 6/i? It'd be greatly appreciated! Thanks!
Old December 18, 2010, 03:40 PM
Trial Member
Talking
I spend more than 3 hours today to get it to work, here is what finally worked for me:
1.Create bootable DOS USB drive, download and follow instructions from here:
link removed:
_www_biosflash_com/bios-boot-usb-stick.htm
2.Download new BIOS from dell, in my case it was R278433:
Drivers and Downloads
3.Unpack downloaded bios on the bootable usb stick.
4.Boot from the usb drive and do update.
That worked for my Perc 6i, here are versions before and after:
Product Name Perc 6/i
before after
Package 6.2.0-0013 6.3.0-0001
FW Version 1.22.02-0612 1.22.12-0952
Bios Version 2.04.00 2.04.00
CtrlR Version 1.02-015b 1.02-015B
I hope it helps somebody, as this thread comes up high on google searches.
After I typed in that post the system refused to let me post links as I am a new user. Way to go forum.
Cannot upgrade Vertex 2 60GB Firmware Modus Storage 10 December 1, 2010 10:07 AM
[WTB] Perc 5i or 6i card catnhat Buy/Sell & Trade 8 August 13, 2010 10:36 AM
[WTB] DELL PERC 5/i, MCR320 or similar n-sanity Buy/Sell & Trade 0 July 23, 2009 06:32 AM
Dell Inspiron 1501 CPU Upgrade BALISTX Mobile Computing 9 March 13, 2008 12:02 PM
