Old November 21, 2010, 03:36 PM
BigHurt88's Avatar
Default Best Bang-for-Buck SSD (120GB or under) right now
Looking to buy an SSD before the holidays. I've been so hesitant due to the price of the damn things. Any suggestions on the best bang for buck SSD right now? Should I be wary of any particular brand?
Thanks for the input and I look forward to your replies!
Old November 21, 2010, 04:39 PM
OCZ Vertex 2 120gb - you should be able to find it for $200 after $30 rebate
Desktop: Asus Maximus V Gene | 3570K @ 4.2Ghz | 4x4GB G.Skill DDR3-1600 16GBXL 9-9-9-24 | Patriot PYRO SE 240GB SSD | Zotac nVidia 560ti | Seasonic X-460FL 80PLUS Gold Modular Fanless Power Supply
http://feedback.ebay.ca/ws/eBayISAPI...onthelam7&iid=
http://heatware.com/eval.php?id=44147
Old November 21, 2010, 08:33 PM
BootlegUsher's Avatar
How does the Intel drive handle garbage collection is you are not in a TRIM environment?
Old November 22, 2010, 06:26 AM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
Intel's self-maintenance makes Sandforce's look positively AGGRESSIVE...BUT it doesn't matter as Intel has their SSD Toolbox and manual optimizer option that basically does a "manual trim" call that will clean the drive even when TRIM is not an option.
Set it up to run once a week and your drive will stay fast for the lifetime of the drive. ;)
Old November 22, 2010, 08:10 AM
BigHurt88's Avatar
Default Thank you!
Thanks guys! Time to spend some money. :)
Old November 22, 2010, 09:08 AM
So that is a program that comes on the CD, and it would be similar to setting up a disk defragmentation schedule?
Edit:
Also, I have heard some big things about Intels Gen 3 drives, such as prices getting cut in half. Anyone know when to expect those?
Old November 22, 2010, 10:43 AM
Edit:
That is all rumours thus far so nobody can confirm or deny.
The Intel G2s provide great performance. I'm quite happy with my 160GB G2. Either way you can't go wrong.
Best bang for the buck dante1 Video Cards 15 December 31, 2009 10:10 AM
bang for buck ssd's gingerbee Storage 5 December 7, 2009 07:54 PM
Best bang for buck? ImAPC Video Cards 5 September 18, 2009 02:31 PM
Bang for the buck Overclocker Alwaysrun Case Mods, Worklog & Gallery 36 May 7, 2009 09:31 AM
Bang for the buck g10 New Builds 8 August 13, 2008 11:19 AM
