Old November 14, 2010, 05:00 PM
yamawho's Avatar
Default How the f&@# do you get esata to work
Purchased a BlacX USB 2 & eSata and no dice on 4 computers ...
If I switch to AHCI in bios ... windows doesn't boot.
Works fine on USB.
What's the deal here ...
Old November 14, 2010, 05:06 PM
sswilson's Avatar
You need to select AHCI before you install windows, and/or do some googling as to how to set it after the fact.
Old November 14, 2010, 06:42 PM
Requires a registry edit because stupid Windoze disables AHCI since it's not needed after your install.
windows 7 solution:
How to enable AHCI in Windows 7 RC after installation | iThinkDifferent
General Tips Switch from IDE to AHCI after Installation [Archive] - TheWindows7Site
Changing BIOS from IDE mode to SATA AHCI mode, after WHS is already installed
For XP (similar process):
HOWTO: enable AHCI mode after installing Windows - PC Perspective Forums
If you have an AMD mobo, it's whatever AMD SATA controller download you use. Go to your mobo website and find which one and do the same except for the AMD-based mobo SATA controller (aka the AHCI/RAID driver for your AMD mobo).
Can I transfer files using eSATA from PC to eSATA on new laptop? Triggz Storage 4 October 31, 2010 06:14 PM
using eSATA technix Mobile Computing 0 December 22, 2009 09:28 AM
eSata Wurmer Storage 19 July 7, 2009 02:53 PM
Back To Work & Thanks Again! rjbarker Off Topic 27 April 7, 2009 04:58 AM
eSata Hotswap? enspirent Troubleshooting 3 March 24, 2009 06:06 PM
