Old November 6, 2010, 10:49 PM
BrianHanna's Avatar
Default little help with ssd firmware
I have an OCZ vertex, with firmware 1.4
does it make sense to upgrade the firmware?
if so, how would i go about doing that? do i risk losing data (it's just the OS anyways i think, but still, dont wanna go through that).
As long as i have trimm, which i believe 1.4 supports, i am fine right?
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old November 6, 2010, 11:24 PM
I too am curious about this subject. I bought an Intel SSD just about this time last year for my laptop but have never done any kind of firmware update. I did see a bit written online about the subject a while ago, wondering if there's a lot of benefit to it and what the upgrade entails.
QuadZilla & The Four Horsemen
Mining Bitcoins with: 7x6950, 3x5970, 7x5830, 2x5850
Old November 7, 2010, 02:31 AM
turtletrax's Avatar
There are usually all the advantages listed in the release notes or changelog of the firmware. Usually worth doing as it either increases performance, solves an issue or increases longevity. But there is also a slim chance of the drive going south.
Not to be alarmist, but I have had one Indilinx Vertex brick on me during upgrade. I did my first two using the suggested upgrade procedure and the third hung and could not be recovered. Ended up with an RMA. Have many SSD's now and have only had the one upgrade issue.
In progress: Other hobbies.
Old November 7, 2010, 04:53 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
When you upgrade the firmware on any device...you risk bricking it. It is very unlikely but it does happen. 1.5 gives you the best of both worlds trim and "ITGC". 1.6 just further refines it. The big thing is...you can not go from 1.4 directly to 1.6. You need to flash to 1.5, reboot THEN flash from 1.5 to 1.6.
Here is where you can get 1.5 and 1.6 firmware.
downloads section
If you are running on windows 7 with the TRIM enabled 1.4 firmware (and NOT 1.41) then the benefits are only minor. BUT Id still do it every little but helps. If you are running an older OS...its a no brainer. Do it. Same with a win 7 and 1.41. I ran 1.31 (even more aggressive itgc) as it is slightly faster firmware compared to TRIM enabled firmware..BUT they also are much harder on the NAND. ;)
Only you can decide but the chances of bricking are VERY slim. YMMV but i like to keep mine up to date.
Backup your data before you do as while it should be nondestructive...its always better to be safe than sorry. ;)
Firmware question for ssd gingerbee Storage 4 October 23, 2012 09:39 AM
A-Data SSD Firmware Update mjbdc07 Troubleshooting 16 June 20, 2010 05:32 AM
[FS] Corsair P128 SSD w/TRIM firmware, like new $260 shipped superj Buy/Sell & Trade 8 May 19, 2010 03:30 AM
Intel Releases New Firmware Updated for 34nm SSD FiXT Press Releases & Tech News 9 December 20, 2009 09:19 AM
A-data SSD firmware is out gingerbee O/S's, Drivers & General Software 0 December 9, 2009 09:43 AM
