It didn't take long - Windows 7 reported disk error too. During post, the Device on my Port 6 (Which is the Raid unit) was reported as Bad. I removed the two drives, reformatted them and checked them for errors - no errors. I also have a Hard Drive docking station - with both drives docked and reading ok. I left the drives running in the docking station for the day - all ok. I reinstalled the drives into the NexStar MX 400 raid enclosure one more time. The eSATA Portduring post, reported the device was bad - again. I connected the MX 400 using the USB connection and the drives were shown ok. The two units are running ok.
I am now left with two possible sources for the error 1) either the eSATA hardware in the MX 400 or 2) the eSATA Port on my motherboard is having problem with a Raid arrangement.
Or what else ?? My other choice is to install the two drives internally and configure them with the motherboard controller for Raid. Any suggestions please.
Thanks.
__________________ ASUS P6X58D-E; INTEL i7 950 ; NOCTUA NH-U12P; PNYGeForce GTX 460 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 8 PRO 64-BIT.
