Old October 29, 2010, 07:33 PM
Default You can connect the ocz revodrive in pci.e 16x??
Hello friends! comes time to buy ssd and I found the OCZ SSD RevoDrive PCI-Express, my question is if I connect to a pci.e where you put a video card in my case I have a 3 way SLI GTX260 and he is free only the last pci-e slot on the motherboard 3 rampage extreme, I mean the 4th pci.e red.
From the pictures it seems that only pci.e walk in the little ones ... and that makes me hesitate when deciding to purchase
Greetings!
Old October 29, 2010, 07:37 PM
sswilson's Avatar
Unless times have changed, you can run any "lower" PCIe card in a higher rated slot.
PCI Express - Wikipedia, the free encyclopedia
a PCIe card will physically fit (and work correctly) in any slot that is at least as large as it is (e.g., an 1 sized card will work in any sized slot);
Old October 29, 2010, 07:39 PM
SugarJ's Avatar
You can put the Revo Drive in any PCI-E x4, x8 or x16 slot on your mobo. It will NOT work in a PCI-E x1 slot.
The PCI-E slots are the same electrically. For example, I run a PCI-E x1 sound card in a x16 slot with no problems.
Edit: Ninja'd!
Old October 29, 2010, 07:42 PM
Hello! thanks for answering! bone, the answer is yes, you can use! that good .. then to buy revodrive!
OCZ Launches 'RevoDrive X2' A Second Generation Bootable PCIE SSD FiXT Press Releases & Tech News 7 October 28, 2010 06:17 PM
OCZ RevoDrive 120GB PCI-E Solid State Drive Review Comment Thread SKYMTL Storage 17 October 20, 2010 11:19 PM
[WTB] Motherboard with 2 pci-e 16x slots Phobia Buy/Sell & Trade 7 April 29, 2009 09:24 PM
[WTB] AMD or INTEL motherboard with 3-4 PCI Express 16X Slots elec999 Buy/Sell & Trade 0 February 28, 2009 08:23 PM
