Old December 18, 2007, 05:34 PM
mattydies's Avatar
Default Partition Questions
MY Father's Laptop had its 60GB Hard drive split in two equal partitions. This was done at the factory. Can this partition be un-done without affecting the Files? (and the current windows installation).
The 2nd partition is not used by my father, but I am wondering if the computer would STILL be sped up by removing the partition?
Matty
Old December 18, 2007, 07:00 PM
That 2nd partition is a recovery partition and you'll notice absolutely no differece in using it except a few extra gigs of space.
Old December 18, 2007, 10:11 PM
mattydies's Avatar
Both Partitions are about 30 gigs, but space is not the issue.
Would the Computer run AT ALL faster if the hard drive was a single partition? (Keeping in mind the 2nd partition is not intentionally used, but it may be used by the system without my knowing).
Even a small speed boost would be a nice bonus :)
Old December 18, 2007, 10:13 PM
werty316's Avatar
It wouldn't make a difference.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old December 18, 2007, 10:15 PM
mattydies's Avatar
Dang
Oh well, IT was worth the ask. And makes less work for me
Thanks for the help guys
Old December 18, 2007, 10:25 PM
werty316's Avatar
Only benefit would be you'd have one 60GB partition instead of two 30GB partitions.
Old December 23, 2007, 05:57 PM
Increasing the RAM would be the biggest speed boost.
Questions and Recomendations Brando737 HTPC Systems & Software 2 September 20, 2008 09:25 AM
Cooling questions... Jaret Water Cooling 35 December 11, 2007 06:48 PM
Some questions about F@H qwerty HardwareCanucks F@H Team 4 October 16, 2007 06:45 PM
some questions about the pc... omgwtf CPU's and Motherboards 17 August 17, 2007 09:44 PM
Partition problem... omgwtf O/S's, Drivers & General Software 1 July 13, 2007 12:55 PM
