Old October 20, 2010, 01:53 PM
Delavan's Avatar
The reason why I still use XP is precisely for scenarios like the revodrive. TRIM hides MANY sins. XP is a worst case scenario for SSDs. It removes TRIM from the equation and gives a good look at the real workings of the controller(s) and the pros and cons of its design. I may opt for a AMD rig as their "issues" with TRIM may just make it the NEXT gen's "worst case scenario".
Awesome AKG! We need that kind of "no bull -REAL real world" scenarios...
I won't buy REVO until it's fully TRIM-capable (might get a 80GB or 120GB THEN). I won't go AMD (X6 eventually) platform until it gives the same SSD performance/TRIM as Intel controllers...
Thanks for letting the "audience" know what's going on!
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old October 20, 2010, 02:34 PM
Originally Posted by AkG View Post
Thanks guys I appreciate it. The RevoDrive is a beast that just needs some TLC for it to be killer choice.
A full testbed w/Win 7 upgrade is in the works. Though a bad mobo has put that plan on temporary hold. I might just skip intel x58 chipset and wait for the next gen.
Using an operating system that removes functionality is hardly beneficial to judging how a product is intended to perform within an environment it was designed for.
Old October 20, 2010, 02:51 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
These drives are intended for more than one environment as the enthusiast community uses more than one operating system. If such a day comes that 100% of all users USE Windows 7 (for example) I will indeed consider including "easier" tests as things such as self-maintenance abilities will no longer matter. Until such a day arrives I consider it to be a much better idea to have worst case scenario numbers rather than glowy/showy "everythings perfect" numbers that you can find in most reviews. You can always ADD to results to get a good feel for how it will handle under less demanding circumstances. Its much harder to guess how bad things can get if you try to scale down.
You have to understand, how the SSD/HDD handles XP IS in and of itself a test for me. I learn just as much if not more from how it handles this handicap as I do from the synth benchmark results. Thats how I can explain and put all the test results in their proper perspective. Testing and reviewing a SSD/HDD (or anything for that matter) is more than just running a bunch of tests and pointing out how it handled itself in each.
Old October 20, 2010, 03:40 PM
FlyingFish's Avatar
Originally Posted by BootlegUsher View Post
I didn't know there were AMD problems, could you elaborate?
AMD doesnt have any AHCI drivers that support trim. So if you have an AMD board you have to use MS drivers for AHCI.
And even then nobody seems to be sure if the trim commands are passed through.
Old October 20, 2010, 03:48 PM
Soultribunal's Avatar
Yuppers, thats why you get a Kingston V or something with a very agressive ITGC (or whatever the acroynm is) and at least that keeps the drive almost as fast as on an intel system.
ST
Old October 20, 2010, 04:00 PM
sswilson's Avatar
Worse than that... the MS AHCI apparently doesn't play nice in the sandbox with the new intel controller so in that case, using the MS driver isn't an option either.
In fairness, it's not just AMD chipsets, it's all chipsets except intel. The problem is that PH IIIs motherboards only come with AMD chipsets, so SSD options are limited.
Old October 20, 2010, 07:24 PM
Default Sadly...
No Crucial RealSSD C300's tested running on a SATA III bus? wa wa wee wah!? It has garbage collection AND TRIM via RST 9.6 driver... even in RAID!!!! It uses the 6Gbps Marvell controller. I'm tired of hearing about Sandforce and Indilinx. obviously not on the same scale as Marvell right now anyway.
PS, i love my Crucial RealSSD C300 64GB!!!!!!!!
Old October 20, 2010, 11:19 PM
So how am i to ascertain how well or even if the TRIM function works on any of these drives when it's not even tested ?
Corsair Force 40GB Solid State Drive Review Comment Thread SKYMTL Storage 7 September 19, 2010 09:28 AM
Corsair Force 120GB Solid State Drive Review Comment Thread SKYMTL Storage 3 July 27, 2010 10:29 AM
G.Skill Phoenix 100GB Solid State Drive Review Comment Thread SKYMTL Storage 9 June 26, 2010 02:46 PM
OCZ Vertex 2 100GB Solid State Drive Review Comment Thread SKYMTL Storage 24 June 12, 2010 06:30 PM
