Old October 19, 2010, 09:09 AM
Default A raid of partition (short stroking)
Is that possible to do a raid ) of partition?
For example i got 8 partitions and 4 hdd, is it possible to run the 8 partitions (assuming that they got the same space) in raid 0?
I have seen some article on this but nothing is really clear!
Old October 19, 2010, 12:42 PM
Perineum's Avatar
You raid the 4 harddrives. All four harddrives now show up as one hard drive
After that you can partition the raided drive however you see fit.
Old October 19, 2010, 12:56 PM
You raid the drives then partition them then raid the partition then partition the partitions and raid them and then set up the partition in raid 0 on the raid with the partition, partitioned.
Old October 19, 2010, 02:46 PM
JD JD is offline
You can convert them to dynamic disks though and "RAID" the partitions.
But yes, you should really just RAID the 4 hard drives together and then make your partitions as you see fit. Especially if you want it all in RAID0.
You could use Dynamic Disks though if you wanted different levels of RAID amongst the drives for whatever reason.
Old October 19, 2010, 03:04 PM
botat29's Avatar
jdrom, just a small note: with dynamic disk you don't call it partition, you call it volume.
Old October 19, 2010, 05:30 PM
MpG's Avatar
MpG MpG is offline
Just because it hasn't specifically been mentioned yet - even if you could, there's no point in doing RAID 0 with partitions, since you'd still have multiple partitions relying on a single HDD's reading mechanism.
Old October 20, 2010, 12:43 PM
Default Short stroking
What I want to know is this:
Could we do it?
http://www.tomshardware.com/reviews/...-hdd,2157.html
Old October 21, 2010, 06:46 PM
MpG's Avatar
MpG MpG is offline
Could we do it?
You could, but why bother? Just use a defrag program that pushes frequently-accessed files to the outer edge of the HDD platters, and you'll get the same effect, without sacrificing capacity, should you happen to need it in the future.
Old October 24, 2010, 11:01 PM
just short stoke it, thats what i did and it works great
Gaming Rig: Intel 930 @ 4.2 (Phanteks TC14) // Asus P6T DLX // 24gb Mushkin 1600 // MSI 980TI @ 1485mhz / 3750mhz // Crucial M4 128gb // 2x Samsung 850 250gb // Thermaltake Toughpower 1200W // Phanteks Enthoo Primo // Asus PB278Q
HTPC: Intel 920 @ 3.5 (Phanteks PH-TC14CS) // AsusX58 Sabertooth // 12gb Corsair 1600 // MSI 390 @ 1100mhz / 1600mhz // Crucial M4 60gb // 640gb WD Black // Antec Truepower 750 // Fractal Node 605
SSD How to merge unallocated partition to primary partition in Windows 7 Mark Troubleshooting 22 May 14, 2010 04:32 PM
Partition editing and Raid 0 whsper Storage 2 August 12, 2009 09:07 AM
how do you make a bootable Vista partition on RAID 0??? howdid Troubleshooting 2 August 2, 2008 09:37 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
Fat Partition to NTFS Boot Partition PaxeSalute O/S's, Drivers & General Software 1 May 2, 2008 01:28 PM
