Old October 18, 2010, 07:17 PM
JD JD is offline
I'd personally suggest the Samsung F3 1TB. I have a total of 5 of them in my house. 3 of them are in RAID5 alongside my Vertex 2 and the other 2 are part of a RAID10 array on my server with the other 2 drives being 7200.12s.
All of them are running great thus far. Same goes for the 7200.12s though, but they're slightly slower. Nothing drastic though. I did have some issues with a 500GB 7200.12, seemed it got pretty badly corrupted or something and needed a low-level format via the SeaTools utility until it worked again.
Old October 18, 2010, 07:19 PM
In terms of performance Samsung=WD>Seagate>Hitachi.
In many cases the Samsung F3's out perform or are very equal to the WD Blacks. The others perform marginally better. So I'm going to +1 jdrom's suggestion for sure, since the Samsung 1TB F3 performs like the WD black at the price of the Seagate.
Old October 18, 2010, 07:55 PM
odis172's Avatar
I have to throw my 2c in, +1 for the Samsung 1TB F3 HD103SJ. I have four of them running without a hitch. Make sure you get HD103SJ not UJ, uj's are the older slower model.
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old October 18, 2010, 08:04 PM
Seems like the samsung f3 is pricing at 79.99.
I think I will probably go for seagate since it's only 59.99.
Old October 18, 2010, 09:03 PM
If it helps, I have one Black Edition and one Barracuda 7200.12 and have nothing bad to say about either.
Old October 19, 2010, 05:41 AM
You should be able to find an F3 for 60 ish too.
Old October 22, 2010, 03:38 PM
I have a 1tb Black running my OS, working great. Also got a 1tb green that was in an external drive I got 1.5 years ago, took apart and put in my system last month. It's just holding movies and TV right now, but when I open it I can hear it spin up... personally I would rather pay a fer cents extra on the power bill to not have to hear it spin up everytime I access it.
Old October 26, 2010, 10:44 AM
I have 2 1TB 7200.12 drives in my system and they work great. Got them for about $40ish + tax each and I think they're pretty much as fast as WD Blacks or F3s, but maybe slightly slower which you can only see in benchmarks and not real world performance. Unless you want the absolute best performance, I'd go for whatever you can get the cheapest whether it be Seagate, WD, or Samsung and save some money :D
Best (free?) program to image a system drive to a bigger drive? oblisk O/S's, Drivers & General Software 2 September 19, 2010 02:38 PM
OCZ Launches Next-Gen Z-Drive R2 PCI-Express Solid State Drive FiXT Press Releases & Tech News 0 April 6, 2010 10:07 AM
How do I set my second hard drive as a "data drive"? lsquare Storage 11 March 19, 2010 09:11 PM
The Best Drive for my Needs Rocco_360 Storage 3 May 31, 2009 07:40 PM
Drive image of win98se on a usb drive Jonwall O/S's, Drivers & General Software 7 May 26, 2009 03:32 PM
