Old October 6, 2010, 02:02 PM
Delavan's Avatar
Vertex 2 120Gb sells for $219 after MIR this week at NCIX.COM
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old October 6, 2010, 02:15 PM
Agility 60GB OCZ, I got one recently for my HTPC set up couldn't be happier. I got Dead Rising 2 and RE 5 on it blazing fast boot up. Smooth boot in to XBMC.
Old October 6, 2010, 03:05 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
The difference between the Agility 2 and Vertex 2 is the firmware. If you are going to get an Agility 2...might as well look around at the other mfg'ers as the Agility 2 is the same as teh Corsair Fore, Pat Inferno...etc etc.
Vertex 2 120 for 219 is a killer deal. IMHO.
As long as you OS is windows 7. I assume it is from your sig...but just in case this is for another XP/Vista based system....dont go the SF route unless you have a trim capable OS. Plan on running in AHCI modeo too otherwise you wont get TRIM and SF's get into a degraded state way to easily if TRIM is not a possibility!!!
Old October 6, 2010, 05:49 PM
Default What about G.Skill
Nobody mentionned the G.Skill Phoenix Pro 120 Gb.
It's based on the same SandForce controller and boasts similar specs. I also have a great "relationship" with my G.Skill parts that never went bad.
Any reason for nobody recommending it?
I'm in the similar 200-250$ SSD buying mood and I'm eyeing either the OCZ Vertex 2 or G.Skill Phoenix pro 120Gb.
Old October 6, 2010, 06:18 PM
JD JD is online now
I think most lean towards OCZ because they offer the best support? IMO at least.
Old October 6, 2010, 06:30 PM
AkG's Avatar
The 120 Phoenix is just another crippled SF drive. Nothing special as it also just uses the std mid teir nand. Unlike how the 100GB version did it (for at least a while anyways)
Old October 6, 2010, 06:57 PM
Hitikiro's Avatar
I would also recommend OCZ Vertex 2. I just picked up a 60GB one and I am using it as a boot drive with some games. These Sandforce SSDs are speedy!
Intel Q9550 @ 3.95ghz (1.32v) | Abit IP35 Pro "Snake" | 4 GB Kingston HyperX T1 PC2-8500 | Thermalright Ultra 120 Extreme w/2 X NF-S12B | MSI 465GTX GE (unlocked to 470GTX) | Corsair HX520 PSU | Boot Drive: OCZ Vertex 2 60GB SSD | Storage: Seagate 500GB HDD | Antec P182 Case | 3 Yate Loon DS12L (undervolted) | 2 x Pioneer DVR-212D | Samsung 226BW
Old October 7, 2010, 12:58 AM
fishingfanatic's Avatar
Smile Storage
Well, the OCZ Vertex II was rated 7.9 of 7.9 in Windows rating. The Kingston was 7.4 and the Agility was 7.3.
Take the Windows rating with a grain of salt, as even the 980x and 1866 tri channel mem. only rate 7.7
I tried all 3 for an OS, and without a doubt would recommend the V II. For me, I would recommend the 120gb, though some people would say 60gb. More free space makes longer life cycle.
Newegg has them for about $245 + tax and shipping.
  #19 (permalink)
Old October 7, 2010, 06:31 PM
Direct Canada has it for 208$ after MIR. With shipping and taxes, it's like 265$ and 235$ after the rebate.
OCZ Vertex 2 Extended Sandforce 120GB 2.5IN SATA2 Solid State Disk Flash Drive SSD - DirectCanada
Is that a good price or do you expect that it will go for much less with the black friday in a month or so?
Thanks for the info!
  #20 (permalink)
Old October 12, 2010, 01:35 AM
the C300 Crucials are every bit as fast as Vertex 2's with the added advantage of being sata lll compatible
Help recommend a Mobo quikgp CPU's and Motherboards 6 June 26, 2010 03:34 PM
Anyone have a Cyberpower pc? recommend? johnnyblazzwa Member Reviews 12 January 25, 2010 09:18 PM
Recommend me an LCD tv! Eldonko Off Topic 24 November 10, 2008 08:20 PM
what do you recommend jay51 Cases 8 July 2, 2008 03:00 PM
How much power would you recommend? Cptn Vortex Power Supplies 7 December 10, 2007 02:35 PM
