I’m more confused than ever! Has been reading for two months now (still almost @ squire one)! I really like your site and your reviews! (Should find it sooner! My system never will be ready!) I’m trying to build a new system and would like to have at least
1GB plus WRITE and read speed in raid zero on the budget (under $1000 for SSD)! I’m really not concerned about the size just speed! Most mother boards have 2 x6GB and 6x3GB controllers! The 2x6GB is good for 2x2TB storage drive.
Is the onboard controller will give that speed?
Which configurations would give me the fastest WRITE-read speed at the lowest $s amount? (Get six of the budget SSDs or go with like the OCZ agility2 or vertex2)?
Could I kind of multiply the WRITE-read speeds per drive with Raid 0? (Exp. 6x250MBs will=1500MB\s)
I do copy and paste a lot (folder-folder than final to storage) 70% of the time 1 to 8GB files! But the 30% is killing me when the file sizes are very small and add up to few hundred MB or a GB!
Thanks
Ps. I will go with the I7-930 Cpu! MB is still up for grab!
