Old September 5, 2010, 11:55 AM
Default External HDD cutting out
I just bought a seagate 2tb hdd and a vantec nexstar CX enclosure. The enclosure was basically the cheapest in stock at canada computers that did esata so that could be part of the issue. In the process of backing up my files to it for an extended write the data stops transferring and the activity light on my old external as well as this one stop flashing. Then the 2tb drive disappears from windows and i have to power cycle it and rescan for it.
Both externals are hooked up by esata, the drive model # for the 2tb is ST32000542AS. Seems like it could be the chipset on the enclosure since the drive itself is only getting up to 40c. Any ideas of what could be causing it would be great
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
External USB 2.0 HDD for HTPC mneszt Storage 5 August 2, 2010 10:20 AM
External Bootable HDD vman1949 Storage 1 October 16, 2009 08:15 PM
External HDD speed? Delavan Storage 3 April 15, 2009 07:23 AM
External HDD Inik Storage 4 March 1, 2009 04:33 PM
External HDD what to buy dougie Storage 8 October 17, 2007 04:54 PM
