Originally Posted by poohbear by the way, does this problem also effect the crucial c300 64gb? Its the newer micron controller, and it relies heavily on trim to keep its performance up, so would that mean im totally screwed w/ this SSD since TRIM wont work properly w/ my AMD chipset?? |
From what we've discussed in the previous posts, no one 100% knows. Apparently some people say (myself included) that the standard Win7 ATA drivers work and trim, and others say they dont.
"Try it, test it, and see" is the general answer. Or wait for AkG to do it for you...
