Sorry, but that's not correct Sagath, it's close but you missed a step.
disabledeletenotify = 0 indicates TRIM is active in the OS. (Note that this only means the OS is trying to send the TRIM command to the drive, if the drives firmware does not have TRIM, the drive will not TRIM.) |
This indicates that the OS is indeed setup to send the trim command, but does not say whether or not the chipset drivers are passing the command along to the drive. As it stands... only intel chipset AHCI drivers, and the default M$ AHCI drivers pass the trim command through to a SSD. Other chipset AHCI drivers (such as AMD & Nvidia) do not currently pass the trim command through.
Up until now, this wasn't a huge issue as the M$ default AHCI driver worked fairly well, although with a small(ish) penalty to performance (guessing around 10%). Sandforce changes this dynamic though as it appears that it doesn't play nice in the sandbox with the default M$ AHCI drivers.
The lack of trim command for AMD AHCI drivers is a well known issue that has to date not been addressed by AMD. In fact, when I sent an inquiry off to AMD tech support about the issue, the answer I received suggested that I contact the motherboard manufacturer..... not much help there as it's AMD who both license the chipsets, and provide the drivers to the motherboard manufacturers.
