Old August 7, 2010, 09:13 PM
tangrisser's Avatar
Default Need Help with RAID 5.
Fellow HW Canucks.
I've been meaning to build a system that's dedicated for downloading and acting as an all-purpose file server. Of course, I am considering using RAID 5. I'm looking at installing 8 - 10 hard drives.
But I'm very much contemplating how I should build the RAID. I had some debate with coworkers whether or not I should be using Software or Hardware based RAID. I'm not really interested in performance since there will only be me and my family who will have access to the computer. I would like some redundancy but these are not really critical data.
I've already read the wikipedia's explanation of RAID.
It doesn't go too much in-depth in terms of advantage and disadvantage of Software and Hardware RAID.
Also, is RAID 5 ideal or should I be considering a different RAID setup?
Any insights, links, information would be greatly appreciated.
Enlighten me!!!
Check out my SALE page
Old August 15, 2010, 05:29 PM
lcdguy's Avatar
well almost all the time hardware raid is superior to software raid. regardless of the raid level but more so when using raid levels that use parity (5, 6). as for which raid level it all depends on how much space you want use and how important the data is. the most common raid levels are 0, 1, 10, 5, 6
raid 0 - striping, putting all your drives into one big array. huge speed boost but lose a drive and the data is toast.
raid 1 - mirroring, duplicates data across 2 disks at the same time. performance is not great. but data integrity is awesome
raid 5, 6 - striping with parity, this is a compromise between data safety from drive failure and decent performance. however for this to be useful you must use a hardware controller. with raid 5 you can lose 1 disk with raid 6 you can lose 2. you also lose a drive worth of space to the parity.
raid 10 - mirroring and striping, for this you first need even numbers of disks in your array. you also will only have 1/2 of the total storage available to you. gives great performance for random IO and good protection from drive failure. also there is no parity so the overhead is low.
i would also consider WHS as an option as it doesn't use raid, it allows you to mix and match drives and provides folder duplication so when a data file is written to one drive in your array it is copied onto another drive.
but if your set on getting a good nas with 8-10 drive capacity this is what i would recommend.
raid card - look for a second hand perc 5i or 6i unless you have a couple hundred dollars to spend on a controller.
case - i'm a fan of rackmount stuff so a norco rpc450 case
drive caddies - supermicro 5 in 3
NAS OS - freenas or openfiler
if you have a higher budget say around the 2500-3k mark i would look at a SAS card and a supermicro 846 series chassis as it supports 24 drives over a SAS cable.
another thing to keep in mind with raid is some of the non raid edition drives have a feature called TLER enabled which can break arrays which was one of the other reasons i went with WHS.
Does SATA III in RAID 0 (on non-SSD) out performing SATA II in RAID 0 (on non-SSD)? SmallWhiteDragon Storage 15 July 19, 2011 12:19 AM
Do I want RAID? and if so what?? biff Storage 18 February 21, 2010 02:44 PM
I have never used\tried raid Shadowmeph Storage 13 February 5, 2010 08:54 AM
raid 1+0 kyle_L Storage 3 October 18, 2009 02:38 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
