Old July 12, 2010, 08:15 PM
Default Caviar Green for operating?
Is the caviar green alright for an operating system drive? I got one for free with my win7 purchase and was just going to throw the drive into my previous computer and run vista off it.
Anything wrong with that?
Old July 12, 2010, 08:21 PM
if you dont do lots of things, i.e. open a movie file and watch it? yup. lotsa things=need for slightly faster drive.
Old July 12, 2010, 09:06 PM
Well it's going to be for my girlfriend. She doesn't do anything extreme but might open the odd movie file.. otherwise my computer does the gaming and main movies to the tv. She mostly surfs the internet and looks at pictures.
Old July 12, 2010, 09:14 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
If you plan on running a WD Green as an OS drive. You better run WDidle3 and change the time out for the head parking from 8 secs to a more reasonable number (or turn it OFF) otherwise you are going to kill that drive within a year or two.
IF wdilde3 cant run on your Green....dont use it as your OS drive. Simple as that.
Old July 12, 2010, 09:20 PM
and the parking thing as well.
Old July 13, 2010, 07:55 AM
It will still be slow as molasses for an OS drive. Why not keep it for backup and backup the data that will inevitably build up over time?
You can get the cheapest SATA HDD for $40 or whatever and use it as the OS drive. Have a copy or original data files on the WD Green.
Old July 13, 2010, 08:48 AM
Hey, sorry for a post immediately afterwards... but, I have a question about WD software. I never use it and if I bought a Green drive, I'd need to use it with XP for a while.
Can the WD Align Utility software be used with a HDD set up in an enclosure? Maybe it only needs eSATA? Or maybe it's best to plug in as normal, run the software and then connect via external drive situation?
Anyone ever use this software? Can you use it with other drives connected? It's a 'Windows installer' file so I guess it will detect the WD drive... but, not sure about whether it works with the drive connected via USB (probably not) or eSATA.
WD Support > Downloads
I'm hoping this is an easy question to answer so I don't have to sign up in the WD Support forum to just ask this. It might even be a stupid question...dunno... I'm only considering this drive since it's easy to get locally and is about the same price everywhere.
I'm out of disk space, temporarily...
Old July 13, 2010, 09:10 AM
AkG's Avatar
Probably wouldnt have any issue with eSATA. USB....hit or miss would be my guess. Best option though is internal connection. Its usually worth the couple extra seconds effort. :)
YMMV
Caviar Green RMA? Kilauea Troubleshooting 10 June 29, 2010 04:28 AM
question about WD caviar Green 1TB ultraman7k Storage 14 March 19, 2010 10:12 PM
[FS] 2 WD Caviar Green 1.5TB HDD's kruzn4evr Buy/Sell & Trade 7 November 2, 2009 01:34 PM
