Old July 2, 2010, 12:38 PM
bvsbutthd101's Avatar
Default Hardware Switch
I was wondering if I can keep the hard drive I have now with all my games and programs on it and use it with a new a motherboard, cpu and ram.
Is it possible
Old July 2, 2010, 01:17 PM
Dar_ell's Avatar
If it was me i would back up everything and format, I like to be on the safe side.
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old July 2, 2010, 01:18 PM
There are ways to do this, but you are far better off just reinstalling when you get your new hardware.
Old July 2, 2010, 01:28 PM
But what if I have a lot of games, I mean a lot like 30 games
it'll take for ever to do it all
Old July 2, 2010, 01:31 PM
I'd assume you're using Steam for most of them then.
Use the Steam backup feature, it's not amazingly fast, but it saves a lot of time.
Old July 2, 2010, 01:37 PM
Soultribunal's Avatar
You can attempt to, I've tried it with very few points of success.
What you need to do is a safe uninstall of all drivers (including chipset I believe) and then put the drive with the new hardware, otherwise you'll get no end to BSOD's if your HDD tries to run on a different chipset than it has drivers for.
That being said, in all honesty it is really a good idea to just start with a clean install and heed the advice the other members give you here.
ST
www.realhardwarereviews.com
Old July 2, 2010, 01:42 PM
No only a couple of games are on steam, but most of them are just downloaded off the internet
Old July 2, 2010, 02:47 PM
Ok i have another question, I fried my cpu the other day and I can't get my computer to boot up, I mean nothing comes up on the screen when I turn it on. So when I get this new hardware can I format the hard drive on the new hardware
Old July 2, 2010, 04:47 PM
You should be able to use your old hard drive in whichever way you want (formatting it, retrieving data, etc.) as long as it plugs in to your new hardware. I assume from your "my system specs" you are using a SATA2 hard drive, which should be compatible with any modern ATX or mATX motherboard you may pick up.
How do you know that you fried your CPU? Those are VERY hard to damage through "normal" use... Nothing coming up on the monitor can mean a lot of things, including loose connections, some screwy thing you did to the BIOS which requires a CMOS reset, bad monitor cable, etc. etc... After running unstable CPU and northbridge overclocks for extended amounts of time (and crazy amounts of BSOD in Windows and Kernel Panic in Linux), my Phenom 9950 CPU is fine.
Old July 2, 2010, 05:02 PM
I'm not sure if the cpu is fried but I've done everything to reset, I've checked my cables multiple times everything is plugs in all the way, I even tryed using a different monitor but still no go. Doesn't matter just order my new parts.
EVGA x58 FTW3 motherboard
4 gb Corsair dominator gt ram
intel core i7 930 cpu
This upgrade is for the better :)
[WTB] Gigabit switch Sipek Buy/Sell & Trade 1 April 27, 2010 09:03 PM
Router + Switch Mr. Gruntsworthy Networking 12 January 6, 2009 11:44 PM
ROuter switch v0maru Networking 2 December 19, 2008 11:44 AM
My Switch Mod kcksteve Networking 0 September 24, 2007 04:25 PM
