<~----> HDD temperatures? - Hardware Canucks
Old July 1, 2010, 08:30 AM
Default HDD temperatures?
What hard drive does everyone run and what temps are they getting ?
I've read that the WD black's run hotter, so I'm looking for a balance of perf. and relatively low operating temps, I jumped on the 1TB WD blue that canada computers had on sale, but wondering what temps the blues operate at while in a case.
The drive won't be used for OS, but more for storage (storing raw vids from capturing).
right now in my old rig, i have 3 drives, a 250gb, and 2 320gb. The 250 runs hot (to me), running at low 50's, where as the 320's I have run at low-mid 30's.
Old July 1, 2010, 08:44 AM
if you have (almost any kind) airflow youll be fine. bar the rappies and so on that are quite the hotties.
as for ssd's some have good thermal transfer with the casing(i.e. external heatsink) others not so.
Old July 1, 2010, 09:52 AM
yea, i'll be running the intel 80gb, so I think that should be fine. Just want to reduce overall heat in the system as much as reasonably possible.
Old July 23, 2010, 11:14 AM
NaX's Avatar
NaX NaX is offline
Default edit
i have one system with 2xWD blacks in RAID 1 and they are warm (and comparatively speaking, they are the warmest item in my case)
unfortunately I cannot receive a S.M.A.R.T. reading of temps due to they are in a RAID setup
solution - Kingwin IY-8015 ICY Aluminum Hard Drive Cooler (on order)
i'm hoping that with the proper speed (to keep acoustics to a minimum) that I can keep the WD's cool
Temperatures on an x2 555 poroporo Overclocking, Tweaking and Benchmarking 3 May 14, 2010 07:27 PM
Are these temperatures ok? what can I do to lower them? mtrpcic Overclocking, Tweaking and Benchmarking 3 October 19, 2009 11:53 AM
Are these temperatures ok? what can I do to lower them? mtrpcic Overclocking, Tweaking and Benchmarking 0 October 19, 2009 10:38 AM
What temperatures are your HDD? Silvgearx Storage 10 January 31, 2009 03:33 PM
How to measure temperatures? kav Overclocking, Tweaking and Benchmarking 4 November 19, 2008 06:17 PM
