Old June 7, 2010, 07:33 AM
gingerbee's Avatar
Default Paragon Alignment Tool
well i have not tried it yet but will some time this week. looks handy Paragon Alignment Tool - Overview
and it's free until June 30th
Old June 7, 2010, 07:36 AM
sswilson's Avatar
Do you have a link to the "free" part???? ;)
Old June 7, 2010, 07:40 AM
gingerbee's Avatar
White Paper: Partition Alignment Dramatically Increases System Performance
just fill it out and they email you the link right away for me took 30 seconds.
pics of software Paragon Alignment Tool FREE
Old June 7, 2010, 02:18 PM
gingerbee's Avatar
ok here are my results on single disk it works fine but it tried to brick my falcons when dealing with them in raid i had to flash to get them back working so be careful on raid setups but the rest seems ok so far.
Old June 8, 2010, 01:17 PM
chrisk's Avatar
Folding Captain
Heh. Registered, downloaded the software, rebooted, did a CDM bench, did an Acronis backup, installed the software and then I was told that my disk was already aligned properly and no further action required. :P
Fold for team #54196
Old June 8, 2010, 03:56 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
yup it works and is non destructive
fixed a funky win 7 64bit os partition. Didnt mess with my data. Took 5 + 25 minutes (did both partitions...but it can only do one at a time). Fast simple easy.
Interestingly enough it uses a 4096 offset instead of the more typical 2048. But there's nothing wrong with that ;)
Old June 25, 2010, 12:15 PM
Default Disk alignment tool - FREE!
Just noticed this but haven't tried it yet.
Thought this could be useful for some of you. Enjoy until June 30th.
Download the white paper and you'll have access to the tool for free.
[/SIZE][/FONT]
Old June 25, 2010, 12:18 PM
Arinoth's Avatar
As this topic exists already threads merged
Old June 25, 2010, 12:20 PM
Oops, didn't notice it before. Oh well, a reminder for everybody.
[/SIZE][/FONT]
Old June 25, 2010, 04:15 PM
0o0 0o0 is offline
So say I took a fresh (raid 0) volume and installed win7 on it without messing with any partitions, would this tool be of any use or would it just say that the partitions are already aligned (like it did to chris)?
SSD alignment help scruff Storage 16 April 19, 2010 06:28 PM
EA De-Authorization Tool Thund3rball Gaming 4 March 31, 2009 09:04 PM
useful tool software CTA Guides & How-to's 11 September 7, 2008 11:28 AM
i/o shield alignment 999Virus999 CPU's and Motherboards 13 January 15, 2008 11:18 PM
Amd Tool Rapid-X Overclocking, Tweaking and Benchmarking 8 August 14, 2007 09:53 PM
