Old June 1, 2010, 02:45 PM
Shadowmeph's Avatar
Default can I set up raid separate from my SSD drive?
to some this may be a silly question to answer but I will try to explain this better . I have my SSD drive setup for my OS and apps I use on a daily bases. at the moment I have a 600gb drive that I am using for other things like my larger games plus a few other things. what I want to do is install 3 or for seagate 320gb drives ( they are all the same) into raid not sure which raid to use but I would like the best speed I can get out of using those drives. I read about raid ( I am new to raid) and am not sure which would be best but I am guessing either raid5 or 10 , I learning more towards raid 10 because from what I understand it is faster and better over all then raid 5 .
so basically what I want to have is my ssd with my OS on it and then a raid setup and then my 640gb drive. if I could set the 640gb drive into raid I would but I think there would be problems becasue of the size and speed differences
Old June 1, 2010, 03:32 PM
Perineum's Avatar
If I understand what you're saying correctly then what you're trying to do will work.
Old June 1, 2010, 04:03 PM
Shadowmeph's Avatar
cool now I have to figure out how I do this hehe
Old June 1, 2010, 04:11 PM
sswilson's Avatar
I'm guessing the PITA is going to be getting the bios to recognise the raid while still booting off of the SSD..... let us know how you make out though... I've got a pair of 250G HDDs that I wouldn't mind raiding, and am especially curious about doing it after Win7 has been installed on the SSD......
Old June 1, 2010, 05:09 PM
gingerbee's Avatar
it works fine. this is what the intel 9.6 drivers are trim to be passed on to a none raided ssd as your boot and your raided storage
Another Raid 0 SSD question micul Storage 4 May 9, 2010 11:08 AM
Question(s) about RAID, HDD's, and SSD'S AmuseMe Storage 28 September 6, 2009 10:22 AM
RAID 0 in SSD or HDD? Chintu92 Storage 16 August 28, 2009 02:29 PM
Raid or ssd for 150$ (average) Mavvens Storage 21 April 2, 2009 08:10 PM
9 drive ssd raid 0 array tzetsin Storage 3 May 3, 2008 11:03 AM
