...could not read NVRAID.sys???
I try to install a RAID 0 on ACER 360 (second computer). I found the drivers, even two versions;2005 and 2006.
After F6, I load the drivers and then, the system response ...could not read the NVRAID.sys on the floppy, but I can read it with another computer!
This is with Windows 32.
I try before loading a F6 with 64 bit drivers with Win64 and got similare response like the NVRAID.sys is corrupted!
I try with a floppy connected with flat cable and also with USB floppy!
It is an ACER AMD 3800 with 2GB of 400 MHz DDR...
What could be the problem?
Thank you
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
