Old May 19, 2010, 09:26 AM
Trial Member
Default raid 0 question
Can a RAID 0 be created using an existing drive that has data on it without losing any data?
I have an existing 1tb drive and have one that i just got.. ..
heres the situation.. i am getting a intel x25-m 160 and using that as my boot drive.. but i currently am running 2 250gb's in raid 0 and i want to take those out and use one of my existing 1 tb drives and use the new and raid it but i dont' want to lose the data on the other 1 tb drive and don't have enough room to backup the data on the tb drive.
any help?
Old May 19, 2010, 11:20 AM
any help?
No, you can't do this. The drives are completely wiped out when you create the RAID array. You'll need to find a way to copy your data over then create the array. If you have unlimited upload/download connection, you could look at Amazon S3 (although it'll take a lot of time to copy your data over).
Else, find a way to sotre all your data on your two 250GB and your SSD (compress data if possible).
Good luck
[/SIZE][/FONT]
Raid question Olorin Storage 12 January 25, 2010 11:09 PM
Raid Question Chromey Storage 10 January 14, 2010 04:34 AM
Question on Raid 1 Bojamijams Storage 13 October 3, 2009 12:23 PM
I have a question about RAID... The MAX Storage 16 May 8, 2009 02:30 PM
RAID Question Wein13 Storage 7 October 12, 2008 06:15 AM
