Old May 11, 2010, 03:05 PM
Patramix's Avatar
Default help with SSD speed (fixed)
running an OCZ Agility 60g (1.5 FW)
kinda messed up my drive, was doing crap and did something that messed up the drive, basicly filled up the drive with a gigantic file
anyways sence then(couple hours) my SSD as been crap, no write speed at all, cant even run a benchmark, talking about a few mb/s writes, for some reason TRIM doesnt seem to be cleaning up i guess
is there a way i can manually run a TRIM or something to get the speed up?
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
Old May 11, 2010, 03:16 PM
gingerbee's Avatar
can't you run wiper on 1.5? um um akg don't you run vertex on 1.5?
Old May 11, 2010, 03:19 PM
Patramix's Avatar
i finally got wiper to run, speed are back up (mostly, not as high as before)
that was odd, trim either couldn't keep up with a 30-40gig deletion or it isnt working properly
My Boinc Stats
Old May 11, 2010, 03:31 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
yeah 1.5 and wiper should work gingerbee.
Also 1.5 comes with ITGC so even if trim is not working....letting it idle will bring the speed back all on its own. ;)
For trim you need: A) Trim aware OS B) Trim enabled firmware c) AHCI mode in BIOS and D) AHCI drivers that can pass on the trim command.
IF any of those 4 things are missing you wont get trim. Since A and B are already known good for you and your setup (win 7 and fw1.5)....the question becomes are your running it in AHCI w/ either latest Intel drivers or the default MS ahci drivers?
Old May 11, 2010, 03:43 PM
gingerbee's Avatar
ya i thought wiper and itgc both worked on 1.5
Old May 11, 2010, 03:52 PM
Patramix's Avatar
well in theory i got all of them , running windows 7
do have a question, i have the asus p7p55d-e, and i got the SSD hocked up on the marvell Sata3 ports with ACHI enable, will trim still work or should i use the intel controler(sata 2 witch am also running my raid 0 from and is set to raid in bios)
and for drivers, witch ones should i use, think ive updated them recently, but cant remember.
My Boinc Stats
Old May 11, 2010, 05:43 PM
gingerbee's Avatar
good questions? i Think you should be fine but that's a total guess
Old May 11, 2010, 05:48 PM
AkG's Avatar
You are better off running it on the intel controller. It will be a bit faster then the marvel. As for the marvel and trim, I havent heard of it not passing on the trim command...but then again I havent heard of it doing so either.
You should be using the Intel rapid storage ones. It can pass the trim command when there is a ssd and raided hard drives.
Old May 11, 2010, 06:22 PM
Patramix's Avatar
ok, good to know, ill try swapping it to the intel controller and see if it helps.
My Boinc Stats
what is bus speed kuziwk CPU's and Motherboards 7 January 20, 2010 12:51 PM
Need For Speed Shift cmac79 Gaming 41 April 26, 2009 07:45 AM
Speed up your internet... Squeetard Networking 14 January 13, 2009 12:31 PM
Transcend Introduces High-Speed 64GB 2.5" SSD MAC Press Releases & Tech News 0 June 24, 2008 01:37 PM
timings vs. speed Mr. Cipher RAM 22 February 15, 2008 05:07 PM
