Old May 9, 2010, 10:37 AM
Default SSD question.
Hello I have an older system that I reciently upgraded the video on it. I was also considering adding a SSD. Would my current system benifit from this.
Current Setup:
Windows 7 Ultimate 64
Processor: Intel Core Duo Q6600 @ 3.6 Ghz 1.4V
Motherboard: Asus P5K-E
RAM: Patriot Viper 8GB (1600)
Graphic: XFX ATI Radeon HD 5850 1000/1000
HDD:2X150gB WD Raptor Raid 0
Monitor: HP w2408h
Power Supply: SilverStone Zeus ST85ZF 850W
Case: HP Blackbird
I would use the SSD for boot + 1 game and the Raptors for Data.
My question can I still run the Raptors in raid 0 with a SSD for boot.
Also how much should I pay for the SSD. Any suggestions would be appreciated.
Thanks Ken
Processor: Intel I5 750 @4GHz
Motherboard: Asus Maximus 3 Formula P55
RAM: G.SKILL Trident @ 1073MHz
HDD:Kingston 128GB SSDNow V Series SNV425-S2 Gen 2 SSD
Monitor: HP w2408h
Case: HP Blackbird
Old May 9, 2010, 11:10 AM
gingerbee's Avatar
yes you can and you have a few choice's here but i would say intel 80gb or the 40gb v series depends on your budget. there are other choices just this really seems to fit all needs size speed and support.
Old May 9, 2010, 11:21 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Very few systems dont benefit from getting a SSD upgrade. ;)
As for how much you should spend.....thats easy! As much as you can afford. :)~
What is your budget?
IF you are on a tight budget look at the Intel V 40GB. Decent speed, decent size, decent price
IF you have under 250 to spend. Get a Intel X-25M gen 2 80GB. Good speed, good size, great price.
If you have a lot more then that to spend....get a Vertex 2, Corsair Force F100, etc etc. Sandforce SF1200 controller based drives. GREAT power profile, good size....just damn expensive.
Old May 9, 2010, 12:28 PM
Perineum's Avatar
I'm going to hijack this thread rather than just make another like it but my question should help the OP anyway..... perhaps?
I'm doing a build and I want to get a small (30 to 40gb is fine) SSD for a boot drive. I would like to keep the purchase at around or less than $150 if I could. I've looked at the Intel V 40GB. Anything else I should consider? Customer is currently using a 40GB boot drive and it's virtually empty so small SSD won't be a problem.
Old May 9, 2010, 12:50 PM
AkG's Avatar
AkG AkG is offline
Its hard to beat the V for price to performance. The others like Indilinx and Toshiba based ones are a little on the low side for small r/w speed.
NOW with that being said the 60gb Vertex goes on sale for like 169. Which is also a good deal.
Old May 9, 2010, 05:44 PM
Thanks for you quick replys.
Is this a good price.
Intel Corporation SSD SSDSA2MP040G2R5 Nand 905205 - DirectCanada
Monitor: HP w2408h
Case: HP Blackbird
Old May 9, 2010, 07:20 PM
I believe they were on sale for $99 at Newegg a month or so ago. If you want cheaper just wait for a sale.
Firmware question for ssd gingerbee Storage 4 October 23, 2012 09:39 AM
Another Raid 0 SSD question micul Storage 4 May 9, 2010 11:08 AM
Upgrade to SSD question Vdub90 Storage 14 February 10, 2010 11:06 AM
ok have to ask the ssd software question gingerbee O/S's, Drivers & General Software 1 July 9, 2009 06:56 PM
Yet another question about SSD Dave510 Storage 9 April 18, 2009 08:29 AM
