Old April 22, 2010, 12:20 PM
Default External Drive Enclosure - Best Value with Esata
Hey guys, looking for a recommendation on the a drive enclosure:Purpose - storage drive for movies/video to HTPC
the HDD that I am looking at is WD15EARS
I require an Esata connection with USB2.0 as well
What would be the best value for an external enclosure?
Thanks
S
Old April 22, 2010, 12:42 PM
chrisk's Avatar
Folding Captain
I have been using this one for a few years, and have suggested them for people with zero complaints:
NCIX.com - Buy Vantec Nexstar 3 External 3.5IN SATA Black Aluminum Hard Drive Enclosure eSATA USB2.0 - NST-360SU-BK In Canada.
I have a 1.5TB Green in there, that replaced a 1TB Green, and had a 500GB Seagate for a while.
Fold for team #54196
Old April 22, 2010, 01:21 PM
^+1! I agree. It's also a good choice because the WDxxEARS runs fairly cool for a spindle drive but of course, it's at 5400rpm speed. Just remember to align the partition but if you use Windows 7, Windows 7 will do it automatically. It's just easier to do it before you store data on it.
Yeah, the Vantec Nexstar 3 enclosures are good for those drives as you don't need the extra cooling or active fans in the enclosure. The one posted is good and there's also ones in blue for around the same price. You can price match it via newegg, for e.g., to get about 10 bucks off.
I have two of the blue enclosures and they work fine. Make sure you get the model (#) that includes usb and esata.
Old April 22, 2010, 02:12 PM
perfect - using Win 7, so thats a good tip.
I assume that ext enclosures are tough to find (may not even exist) that have an internal power supply?
Need external hdd enclosure for Caviar Black 1TB Bomberman07 Storage 9 December 30, 2009 08:54 AM
FS: A.C. Ryan AluBoxDuo External Hard Drive Enclosure cyberspyder Buy/Sell & Trade 12 December 27, 2009 10:36 AM
2.5" eSata Enclosure - Any thoughts? jgerber Storage 2 February 26, 2009 07:46 PM
Post your external drive enclosure transfer speeds. Cardboard box with DSL Storage 1 June 28, 2008 06:57 AM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
